Old Feb 9, 2016, 10:20 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Interior and dome lights not working
Old Aug 22, 2012 | 07:25 AM
Yamiryder's Avatar
I tried searching this already and have tried a couple of things. My problem is my 92 extra cab. The dome lights will not work. I tried replacing the bulb, checking the fuses, and checking my door sensor, but everything was fine. I don't know what could be wrong. My door buzzer does not come an also. It seems that these things do not have power going to them but I don't know what's causing it. Thanks
Old Aug 22, 2012 | 07:36 AM
waskillywabbit's Avatar
Turned the rheostat for the dimmer on the dash?
:wabbit2:
fdp101452's Avatar
Can you turn the lights on manually with the switch on the light? Door switches are grounds, make sure youre getting a ground through your switch.
Old Aug 22, 2012 | 08:31 AM
Yamiryder's Avatar
Its not the dimmer switch, I messed with that too. I haven't checked for a.ground yet. And I can't get the lights to work manually either
Old Aug 22, 2012 | 08:54 AM
RAD4Runner's Avatar
Originally Posted by Yamiryder
...The dome lights will not work. ... My door buzzer does not come an also.
Door buzzer or key left in ignition buzzer?
Look at schematic in FSM (link on my signature) and see what dome light circuit and buzzer circuit have in common. Where does that circuit get its Pos12V from battery? Where does it get ground?
Best of luck.
Old Aug 22, 2012 | 09:59 AM
scope103's Avatar
Put a voltmeter on the fuse (both sides, since you don't know which is the battery side) to assure you get 12v on both sides. Then check for 12v up at the dome light itself (who knows, you may have a bad bulb.)
Don't have a voltmeter? No excuse for that. http://www.harborfreight.com/7-funct...ter-98025.html Looking for electrical problems without a multimeter is like cave exploring without a flashlight.
Old Aug 22, 2012 | 12:27 PM
Yamiryder's Avatar
Thanks guys I'll try that. The buzzer is for the key left in ignition not door, my bad
Old Aug 22, 2012 | 01:00 PM
RAD4Runner's Avatar
Originally Posted by scope103
looking for electrical problems without a multimeter is like cave exploring without a flashlight.
aahmen!
Old Aug 22, 2012 | 01:14 PM
aviator's Avatar
The dash rheostat is only for the binnacle/heater/radio lights it does'nt affect any other lights in the truck.
I was messing with the main electrical fuse box behind the driver's side kick panel the other day and now I have no dome light/ignition light/key alarm function either... think I may have left a harness unplugged on the fuse box... you need to take the whole panel out to see the whole thing as you know... look for a disconnected/loose plug.
These alarm/delay functions are controlled by the relay box which is plugged into the back of the white fuse box and the harness which plugs into it.
Old Aug 22, 2012 | 02:13 PM
Ocell's Avatar
I've got the same problem in my 88 4Runner. Please update us if you find the problem, and I'll post a note if I get mine solved in the meantime.
Old Aug 22, 2012 | 05:10 PM
Yamiryder's Avatar
I'll have to keep digging. I cant find any blown fuses or disconnected wires
Old Aug 22, 2012 | 05:31 PM
Yamiryder's Avatar
Old Aug 23, 2012 | 12:33 AM
RAD4Runner's Avatar
Guys,
while you're digging in there, if you figure out how to remove this fuse/relay block from the bulkhead, please share pics/description. I already removed the screw on bottom, tried to slide it forward/backward/up/down but it would not budge, and I don't want to force and break anything. Need to access the rear in order to do clean mod wiring.
TIA,
RAD
Old Aug 23, 2012 | 03:36 PM
Terrys87's Avatar
Your dome light wont work if your buzzer box is unhooked on most trucks. It is straight above the brake pedal. Most disconnect the buzzer box to stop the buzzer not realizing it controls the dome light. I have a post on my 88 4Runner build how do disable the buzzer on the first page.
Old Aug 23, 2012 | 03:52 PM
Terrys87's Avatar
On the cut out just above the 15 and 20 amp fuse slide your middle finger until it stops. Your finger should kind of feel like it is inbetween 2 pieces of plastic, that is the release tab. Lift straight up on it and with your thumb and pinky or ring finger you should be able to grasp the fuse box on the sides and slide it straight off (horizontally) of the 2 tabs that hold it at the top of the fuse block.
Old Aug 23, 2012 | 04:56 PM
Tmo77's Avatar
I'm sure this won't help, but I was told the Dome Light Housing in my '95 4Runner is toast. How's your Housing hangin?
Old Aug 23, 2012 | 06:15 PM
Yamiryder's Avatar
My housing seems fine...I'll have to go check above my brake pedal to make sure that is still connected.
Old Aug 23, 2012 | 10:59 PM
RAD4Runner's Avatar
Originally Posted by Terrys87
On the cut out just above the 15 and 20 amp fuse ...that is the release tab.
Thanks Terry! Worked! You Da Man! now I'll be able to clean up my light reminder mod, and finish up my Deck Light Mod so I can turn on deck light from the back without having to scramble to the front to turn on the tail lights.
Old Aug 24, 2012 | 07:56 AM
scope103's Avatar
Before you start tearing up your wiring, consider this:
https://www.yotatech.com/forums/f199...l#post51963941
Old Aug 24, 2012 | 09:17 AM
RAD4Runner's Avatar
Moved post
