ifs cv studs?
Old Mar 6, 2007 | 09:15 PM
GMJK86SR5's Avatar
ifs cv studs?
Do I need to remove two studs, to get at the cv's off,on the trail or should I remove all of them, and replace these with bolts?
Mike
Old Mar 6, 2007 | 09:20 PM
MudHippy's Avatar
No, it's a bit of a pain, but you can squeeze it past all the bolts. Unlock the other axle hub, or shift the transfer case to 2hi. It helps a great deal to be able to spin the stub shaft when weaseling the thing out of there. I wouldn't know for sure about which kind of bolts, sounds like a cool idea though. It'd be tough knockin' those studs out, I've done it, no fun. Maybe it would be advantagous in certain circumstances. Oh, I have to remove the lower shock mount bolt to get mine out, so don't be too suprised there.
Old Mar 6, 2007 | 09:26 PM
slosurfer's Avatar
You could just press them out and instead of getting new bolts, use a bench grinder to take the ridges off the studs so that they slide in and out easy.
Old Mar 6, 2007 | 10:22 PM
AxleIke's Avatar
You can do it with the studs.
I have bolts.
I have watched both ways changed on the trail. Studs took about an hour.
Bolts took 12 minutes, start to finish.
Its a time thing, and and ease of use thing. You can do it both ways, but the bolts are significantly easier.
Old Mar 7, 2007 | 04:24 AM
GSGALLANT's Avatar
I just remove the four bolt on the lower balljoint. That gives me enough clearance to get the CV axle out with all the studs in place.
Old Mar 7, 2007 | 05:53 AM
tc's Avatar
tc
I replaced mine with bolts.
M12-1.25x30mm IIRC
Get a bunch, because that size is also used for the brake calipers, front diff mounts, crossmembers and a couple other things!
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Badlander
Oct 10, 2015 08:05 PM
dirk89
Oct 1, 2015 05:15 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
