ifs cv studs?
No, it's a bit of a pain, but you can squeeze it past all the bolts. Unlock the other axle hub, or shift the transfer case to 2hi. It helps a great deal to be able to spin the stub shaft when weaseling the thing out of there. I wouldn't know for sure about which kind of bolts, sounds like a cool idea though. It'd be tough knockin' those studs out, I've done it, no fun. Maybe it would be advantagous in certain circumstances. Oh, I have to remove the lower shock mount bolt to get mine out, so don't be too suprised there.
You can do it with the studs.
I have bolts.
I have watched both ways changed on the trail. Studs took about an hour.
Bolts took 12 minutes, start to finish.
Its a time thing, and and ease of use thing. You can do it both ways, but the bolts are significantly easier.
I have bolts.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
dirk89
Oct 1, 2015 05:15 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
