If it were your truck...
1994 4Runner 3.0
Manual
4wd
So, the truck was overheating a little and we saw some water coming out from behind the water pump...well, we took it in expecting water pump, timing belt etc. needing to be replaced. We were told it is a radiator issue (which is completely probable!). The mechanic recommended that we replace the radiator, water pump (which we are unsure if it is even a problem at this point) and the timing belt. I understand that it's easier to do it all while you're in there, however, I can't just shell out the money for all of it. So, I guess what I'm wondering is:
If you aren't sure your water pump is bad, would you just replace the radiator and take your chances down the road?
Thank you for your input!
Manual
4wd
1994 4Runner 3.0
Manual
4wd
Manual
4wd
If it were my truck I'd figure out exactly whats wrong with it. If it's just the radiator then fix just that, which like everyone has said is pretty simple. But I don't understand why you would need to replace the timing belt and water pump if it's a "radiator issue"
. If your leaking water from the motor (water pump issue) then the radiator is probably fine. If your only leaking water from the radiator then the water pump and timing belt probably don't need to be replaced.
If you do the timing belt or water pump do them both. The water pump is run off the timing belt, so you might as well do both.
. If your leaking water from the motor (water pump issue) then the radiator is probably fine. If your only leaking water from the radiator then the water pump and timing belt probably don't need to be replaced.If you do the timing belt or water pump do them both. The water pump is run off the timing belt, so you might as well do both.
duckhead
170
Nov 13, 2017 06:07 AM
colsoncj
Mar 31, 2010 05:59 PM
Swissdrums
13
Apr 21, 2006 08:46 PM
