Idle issue
Old Dec 16, 2017 | 10:58 AM
Blue 95's Avatar
Idle issue
I’m new to the forum and am having a idle issue with my 95 Toyota truck. It has the 22re and is a 5 speed. The problem I’m having is when I start the truck it runs fine, but once the accelerator is pressed it idles any where from 750-1500 rpm’s. I had replaced the tps a month ago and was fine, this issue just started. Any help would be great.
Old Dec 16, 2017 | 11:17 AM
scope103's Avatar
Start the easy way. Pop the hood, watch the throttle linkage, have someone press the accelerator. It will be easy to see; if the idle is high and you can bring it back just by pushing on the linkage, you've got binding. The total throttle linkage has a number of parts, and if any are binding they will elevate idle.
Old Dec 16, 2017 | 12:31 PM
Blue 95's Avatar
I see what you are saying. No binding going on. It is weird, when it happens if I turn off the engine and then start it back up, it’s fine, back to 750. But then if I hit the accelerator, it may or may not come back to 750?
redbayredneck
Jun 2, 2014 04:29 AM
nothingbetter
Nov 11, 2013 03:40 PM
kevo4runner89
Sep 13, 2013 04:30 PM
Rob2thec
Jan 28, 2010 10:09 PM
