I need engine help
Old Jul 30, 2008 | 06:16 PM
hurley842002's Avatar
Off topic, but which small town, CO?
Old Jul 30, 2008 | 06:22 PM
wrnchplr's Avatar
Originally Posted by DeathCougar
What is the production date of your 92?
If its pre-may/92, then you had a spring type tensioner. If you installed that 95 engine without intalling the Fan support/Hydraulic tensioner from the 95, it will continue to jump time.
If it has the correct 6/92-95 hydraulic tensioner and all related pieces, you may have a failing/failed tensioner. And i know its a silly question, but (if you have a tensioner) is it screwed in all the way? It needs to be bolted down tight flush to the fan support.
I used the hydraulic on from the 95 also the 92 had the same. I did think of that and used the one from the 92 that had less then 200 miles on it. both are new... I had made sure the bolts are tight, I used the impact gun while it was out.
Old Jul 30, 2008 | 06:23 PM
wrnchplr's Avatar
Small town would be Johnstown. It's east of I-25 between Longmont and Loveland.
Old Jul 30, 2008 | 06:25 PM
DeathCougar's Avatar
I am having a tough time visualizing why its jumping time then. Does it only do it when it runs? Have you tried turning it over by hand several times to see if anything is out of the ordinary?
Old Jul 30, 2008 | 06:34 PM
  #25
wrnchplr's Avatar
Part of the problem is it won't run. I crank it over and it won't start. The motor is tight as all the internals are new so turning it over by hand sucks. I have only turned it about 4 revolutions. I am not sure as to way it is doing this either.
Old Jul 30, 2008 | 06:38 PM
  #26
EWAYota's Avatar
Man, I sure wish I had some 3.0 tech info for ya.
I just know a little in regards to the 22RE, lol.
Sounds like D'cougs on the right track.
Old Jul 30, 2008 | 06:41 PM
  #27
wrnchplr's Avatar
I know the 22re like the back of my hand....Thanks tho....
Old Jul 30, 2008 | 06:56 PM
  #28
If it doesn't turn over by hand, you have a problem with the rebuild. It should never be so hard you can't turn it over with a wrench.
Old Jul 30, 2008 | 07:09 PM
  #29
wrnchplr's Avatar
It will turn over by hand, it's just tight.....I Think I found one of the issues. the new timing belt is about 3 teeth longer then the old one........
Old Jul 30, 2008 | 07:21 PM
  #30
haha uh, yea, that will do it.
I take it you didn't get your parts from Toyota eh?
If you ordered a timing belt from a 95, they may have given you a 95 Tacoma timing belt (5VZ)
Old Jul 30, 2008 | 07:41 PM
  #31
76ANTHONY's Avatar
hey that may be an issue. thats why i always check all belts before install, glad you found the issue, thats gotta be it
Old Jul 30, 2008 | 08:23 PM
  #32
wrnchplr's Avatar
I'm not sure what the belt is for but it no workie on this motor. I installed the old one and still no start. I am beating my head on the desk trying tofigure this out, I'm not a nOOb when it comes to engines. I also tried turning the crank one revolution then installing the belt, still nothing. I can't even get a back fire...it acts like there is no spark at all and I checked the whole system....nice blue spark at every plug.....
Old Jul 30, 2008 | 08:25 PM
  #33
wrnchplr's Avatar
not this time. I got a kit online and it came with a timing set. should have known better....I had to throw the H/G in the trash, they were so thin and look like crap!!!! if I didn't have 1,000's into this motor I would just put in a 22RE-T.....
Old Jul 30, 2008 | 08:31 PM
  #34
scuba's Avatar
anyone with a link wanna hook a brotha up
Old Jul 30, 2008 | 08:52 PM
  #35
76ANTHONY's Avatar
ok heres what my old boss told me on mine, same issue. its called washed out cylinders, its when you try to start your vehicle and flood the cylinders with gas on a new engine it takes all the oil out of the cylinders and the pistons dont have a seal, so you just hold that starter for a while and see if she'll fire up. scared me doing this cause i held the starter on for about a minute at a time, then she woke up and started.....
Old Jul 30, 2008 | 09:02 PM
  #36
wrnchplr's Avatar
Thanks but I know about that. I did wash them out, but the better, funner way to fix that issue is use a BBQ lighter and stick it just out side the spark plug hole makes one hell of a flame
Old Jul 30, 2008 | 09:18 PM
  #37
thefallman's Avatar
its possible that ur distributor is 180 degrees out of sink try adjusting the distributor ur getting spark just at the wrong time.
Old Jul 30, 2008 | 09:25 PM
  #38
if all the match marks are correct with the timing belt, its in time. You can't have the crank one revolution off....since its exactly that. One full revolution, or 360 degrees. That puts it right back to where it started.
Engines have cam gears that are exactly 2x the size of the crank gear. hence the 4 stroke engine.
Old Jul 30, 2008 | 09:26 PM
  #39
904_runner's Avatar
Man, DC you are really working for those pictures, eh?
Old Jul 30, 2008 | 09:28 PM
  #40
shoot, I got the link long ago lol.
Now i am going for the whole series!
I just want to see him get the truck back together, nevermind the boobies! Course...i do enjoy a good pair of em!
