highway speed problem- 87 4runner lack of power up to 60
Old Apr 23, 2017 | 08:19 AM
916yotacrawler's Avatar
I just bought a 87 4runner, on my way to work I was driving on the freeway and I couldn't get my speed up to 60. I accelerated all the way but won't go it seems like it is dropping instead of going and its eating up my gas. does anybody have that problem?
Old Apr 23, 2017 | 08:22 AM
dropzone's Avatar
Fossilized
helps to know if it is an auto or a stick?
what have you checked?
Old Apr 23, 2017 | 08:23 AM
its an stick shift?
I don't know where to check first. have any ideas?
Old Apr 23, 2017 | 10:21 AM
Co_94_PU's Avatar
Throttle position sensor, air flow meter.
A worn air flow meter, one with dead spots in the resistance curve. And similar worn out or unplugged throttle sensor
Make sure those connections are firm and clean.
Old Apr 23, 2017 | 02:03 PM
flg8r22's Avatar
Worn or bad clutch / clogged catalytic converter if you've got one ?
Old Apr 23, 2017 | 02:18 PM
Co_94_PU's Avatar
Exhaust, you will notice a lack of Rpms out of gear as well a different sound. You can disconnect the intermediate pipe at the manifold to test this.
Clutch you'll have higher Rev and less movement.
Old Apr 23, 2017 | 03:23 PM
greyheadedguy's Avatar
Does the 87 22R have throttle position sensor, air flow meter?
grey
Old Apr 23, 2017 | 04:35 PM
wallytoo's Avatar
grey
i don't believe it does. the 22re does, but not the 22r.
Old Apr 23, 2017 | 05:36 PM
Thank you, I was wondering.
I have been working with the same a 22R engine out of an 85 2 wheel drive truck since 2001. I thought I knew it very well and I saw the post and it had me questioning what I knew...
grey
Learning
Oct 2, 2022 05:17 PM
Hungrynomad
Mar 26, 2017 11:56 AM
The_One
Mar 10, 2017 06:48 PM
Andyroo
Mar 5, 2017 03:11 PM
sohofisherman
Feb 12, 2017 08:28 AM
