highway speed problem- 87 4runner lack of power up to 60
Old 04-23-2017, 08:19 AM
916yotacrawler's Avatar
I just bought a 87 4runner, on my way to work I was driving on the freeway and I couldn't get my speed up to 60. I accelerated all the way but won't go it seems like it is dropping instead of going and its eating up my gas. does anybody have that problem?
Old 04-23-2017, 08:22 AM
Fossilized
Staff
dropzone's Avatar
helps to know if it is an auto or a stick?
what have you checked?
Old 04-23-2017, 08:23 AM
its an stick shift?
I don't know where to check first. have any ideas?
Old 04-23-2017, 10:21 AM
Co_94_PU's Avatar
Throttle position sensor, air flow meter.
A worn air flow meter, one with dead spots in the resistance curve. And similar worn out or unplugged throttle sensor
Make sure those connections are firm and clean.
Old 04-23-2017, 02:03 PM
flg8r22's Avatar
Worn or bad clutch / clogged catalytic converter if you've got one ?
Old 04-23-2017, 02:18 PM
Co_94_PU's Avatar
Exhaust, you will notice a lack of Rpms out of gear as well a different sound. You can disconnect the intermediate pipe at the manifold to test this.
Clutch you'll have higher Rev and less movement.
Old 04-23-2017, 03:23 PM
greyheadedguy's Avatar
Does the 87 22R have throttle position sensor, air flow meter?
grey
Old 04-23-2017, 04:35 PM
wallytoo's Avatar
grey
i don't believe it does. the 22re does, but not the 22r.
Old 04-23-2017, 05:36 PM
Thank you, I was wondering.
I have been working with the same a 22R engine out of an 85 2 wheel drive truck since 2001. I thought I knew it very well and I saw the post and it had me questioning what I knew...
grey
Learning
10-02-2022 05:17 PM
Hungrynomad
03-26-2017 11:56 AM
The_One
03-10-2017 06:48 PM
Andyroo
03-05-2017 03:11 PM
sohofisherman
02-12-2017 08:28 AM
Quick Reply: highway speed problem- 87 4runner lack of power up to 60
