Helpful hint #4 stop noise on steering stop
Old Jan 12, 2007 | 06:27 PM
crackerjack's Avatar
Was rebuilding brakes last weekend and got to thinking about the steering stop thats behind each A arm.
We all know how they make that loud creeking noise because the plastic cap has worn.
So I took an old spark plug boot and cut the end off leaving a tube.
Then cut a square from a shop rage filled it with grease then pushed spark plug tube over it and around the stop post.
So far it held with no noise, Just thought I'd pass this idea on
Old Jan 12, 2007 | 06:51 PM
timebandit's Avatar
Mine were never there.
Old Jan 12, 2007 | 07:14 PM
things that make you go uhhmmm...
Old Jan 12, 2007 | 08:13 PM
timebandit's Avatar
Seriously.
Old Jan 12, 2007 | 08:48 PM
dcg9381's Avatar
It's cheap..it works.. no complaints here!
Old Jan 12, 2007 | 09:48 PM
thook's Avatar
What's a shop rage?
Old Jan 13, 2007 | 06:50 AM
eric-the-red's Avatar
Originally Posted by thook
What's a shop rage?
That's what you get when you bash your knuckles on somthing hard and sharp
I always used some antisieze stuff on my steering stops, seems to last a lot longer than grease in the wet.
Old Jan 13, 2007 | 07:09 AM
thook's Avatar
Knew that was comin'!
Old Jan 13, 2007 | 08:46 AM
toyota_mdt_tech's Avatar
Easiest thing to do is to just lay a small bead of grease on the arc where the steering stop hits. Dont ever repalce the caps, waste of $$$ and they wil wear off or tear off.
Old Jan 13, 2007 | 09:11 AM
Sonofmayhem's Avatar
damn that is a lot of toys. MDT...
Old Jan 13, 2007 | 09:12 AM
highway's Avatar
has anyone tried cleaning it with say brake cleaner and applied a bead of silicone on the stop and let it cure ? don't know if it would hold up well or not ?
highway
Old Jan 13, 2007 | 09:14 AM
Targetnut's Avatar
Use antisieze compound it kind of hardens up so it won't come right off.
Old Jan 13, 2007 | 09:43 AM
YotaPower's Avatar
Excellent idea! I've been wondering what that noise was and now I know how to fix it too!
Old Jan 13, 2007 | 12:45 PM
It is "sonofmayhem" and its only as small as it is because I have sold a few already. I spend a mint in licensing every year and will probably thin the herd down some more. The KTM SX50 is next. Grandson races, I sponsor him and he is going to "age" out of that size. I sold 2 cherry Honda CT90's, a 1973 and a 1978. But I dont have any desire to sell anything else. I didnt have any desire to sell the trail 90's, but I'm going to have to draw the line at some point. Everything I have is in perfect impeccable condition, so there isnt a "bunch of work" needed on any of them. :bigclap:
Old Jan 13, 2007 | 12:46 PM
If you guys just lay a bead of grease every other time you change the oil, you'll never hear the creak and groan of dry steering stops ever again.
Old Jan 15, 2007 | 07:12 AM
Pozi's Avatar
I simply removed mine and rotated it until there was plastic coverage. Of coarse this is not a permanent solution (like all others) but the next time I go to the junk yard I just pocket the worn caps from donors.
Old Jan 15, 2007 | 09:27 PM
jimmyray's Avatar
thievs go to hell...................
Old Jan 15, 2007 | 09:54 PM
OK, you keep ignoring the fix. Forget the caps, forget rotating, replacing, stealing used ones from the junkyards. I posted a free fix and a permant fix.
Old Jan 16, 2007 | 06:24 AM
GSGALLANT's Avatar
Although that is the best currently accepted fix, I wouldn't consider it "permanent" since it requires doing something every 5000 miles.
Old Jan 16, 2007 | 01:15 PM
No fix on these are permanent, this is the only one that doesnt cost you $$$
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
