Help with mysterious plugs in dash!!!
Old Aug 20, 2007 | 02:22 PM
Jay351's Avatar
Hey all, I finally pulled my dash out to fix my vent selector and since I had everything apart I wanted to check on some plugs/switches that I had seen with under the dash.
here are some pictures
Here's where it sticks out from the dash, you can turn the end around 360 degrees then it clicks and stops. Its some kind of switch, looks like its a factory location.
AHhhhhhhhh wires!!! WTF I zap strapped the looong grey wires like that, they snaked all around the bottom and where tucked near the fuse pannel.
I don't know about the other cluster of wires that are all taped up though.
Unplugged from that switch..
I have left the plug unplugged and removed all the wires since they where getting in the way.
Now this plug is tucked WAY under the dash and was hard to get to, sorry for the crappy picture, it has quite a few little prongs inside it, any ideas?
thanks for your help, this is realllly anoying. The stupid guy my dad bought the truck from did some real creative wireing...
[img]
Old Aug 20, 2007 | 02:37 PM
justinking060310's Avatar
if it ain't broke, dont fix it?
Kat
Old Aug 20, 2007 | 02:39 PM
Chrisnxl185's Avatar
im pretty sure thats the dimmer switch for the dash board lights
Jay351's Avatar
pshhh, thanks for the help kat
p.s did you get my pm?
*edit*
Its not the dimmer switch, thats up by the clutch start cancel button.
Old Aug 20, 2007 | 02:51 PM
85toy's Avatar
on my 84 thats the dimmer switch. someone might have changed your for some reason.
Old Aug 20, 2007 | 03:01 PM
frodin1's Avatar
The Toyota one was probably to expensive so they rigged in a cheapo.
Old Aug 20, 2007 | 09:58 PM
Jay351's Avatar
Question is, why would he relocate it, seems like more work..
I will grab a picture of the dimmer location tomorrow when it gets light out.
I was sure it was the stock location!
Old Aug 21, 2007 | 01:09 AM
Jay351's Avatar
I was trying to find a picture of another 3rd gen to see if it had the dimmer in the place I do.
Look where the clutch start cancel switch is, and then look about 2" down, you can see the round dimmer switch.
Old Aug 21, 2007 | 06:00 AM
mith's Avatar
On the 2nd Gen pickup I used to own, the place where you have the first switch just had a plastic plug to fill the hole. I don't know what would go there normally, I had planned to run an auxiliary light switch to that spot.
Old Aug 21, 2007 | 06:11 AM
ewong's Avatar
Off the cuff the location is the location for the dimmer on a Gen2 4Runner?
The CONNECTOR looks like an OEM connector
The wires to the rehostat do NOT look like an OEM assembly
The looped up mess of wires does not look OEM
The wire COLORS appear to be an OEM designation.
My guess - its a power fader for speakers that the Preious Owner installed...
ashersullivan88yota
Jan 18, 2022 05:37 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
smiley52
Jul 11, 2015 05:16 AM
bryan34w
Jul 6, 2015 05:53 PM
