help installing mechanical water temp gauge
Old Sep 28, 2008 | 02:29 PM
Cwaters1184's Avatar
it seems like im missing a piece. i dont know if im supposed to or not but i wanted to screw it into the stock sensor spot, which the tap does fine however there no actual seal. can i just put some sealant around it or something? no clue. lol. theres nothing to stop it from just falling further into the tube. what should i do?
http://img.photobucket.com/albums/v1.../sensor002.jpg
http://img.photobucket.com/albums/v1.../sensor001.jpg
Old Sep 28, 2008 | 02:57 PM
95RunnerSR5's Avatar
teflon tape!
Old Sep 28, 2008 | 03:00 PM
black diamond's Avatar
thats not pipe thread and teflon won't help. what kind of set up is that?
Old Sep 28, 2008 | 03:15 PM
what do you mean what kind of setup? the black wire runs straight to the back of the gauge, dont know if thats what you mean. to the other comment yeah teflon tape isnt going to help. The brass fitting (while maybe its not meant for it) threads perfectly into the stock sensor port (and my gauge is messed up so its not like im using it for the stock water gauge and its not the one that goes to the ECU so it should matter if i use the aftermarket one there) problem is the water can just freely come out the brass fitting b/c theres nothing that connects it to the sensor and theres no sealer between the wire and the brass fitting. i hope thats understandable.
Old Sep 28, 2008 | 03:30 PM
is the stock sensor pipe thread? tapered? sounds like it is. what kind of gauge is it?
Old Sep 28, 2008 | 03:33 PM
threaded. its these. someone gave them to me, they're not the best but they should work
http://www.iequus.com/product_info.p...ory_id=100_120
Old Sep 28, 2008 | 03:50 PM
Hayes's Avatar
You need an adapter like this!!!!
Old Sep 28, 2008 | 04:00 PM
drew303's Avatar
Yea your missing the other fitting.
It works like this:
It only worked in the opening on the side of the T-stat housing on my 22R, the stock location isnt deep enough to house the new probe.
Old Sep 28, 2008 | 04:03 PM
oh ok. thanks guys.. i knew it seemed like i was missing something lol.
Old Sep 28, 2008 | 04:05 PM
Hayes's Avatar
It works like this:
is there an echo in the house?
gary4runner
Sep 24, 2015 12:53 AM
Jonny246
Jul 12, 2015 04:51 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
