Help! 1991 4Runner front coil spring??
Old May 11, 2009 | 03:08 AM
Vanman's Avatar
I know I am NOT mechanically inclined at all, BUT...
Long story short, I had the front shocks replaced 2 years ago, and now replaced under warranty because the front were completely done. I know, Sears...but it was what I could afford at the time. Shocks are the sensatrac, although the size (I am assuming) were for SUVs and light trucks. According to my Chilton book, I should have front Springs!! They are NOT with the shock, like the rear shock/spring assembly. Am I an idiot (the springs are located somewhere else and I am too blind and inept to see them), or is this something Sears forgot to reinstall? (I would think this would be close to an impossibility, but that is why I am asking).
On another note, I haven't logged in for a while, I finally got the running boards off and can tackle the rust this summer!
Thanks!
Old May 11, 2009 | 04:40 AM
93toyrunner's Avatar
I have never seen coil spings in the front of a 4runner older than 96 I do not have any in my 93 only torsion bars
Old May 11, 2009 | 05:57 AM
scuba's Avatar
Step away front the chiltons.
You have torsion bars, Not coil springs..
Look for a LOOONG bar running from your front upper control arm down the side of the frame..
Like this
Old May 11, 2009 | 07:37 AM
Tofer's Avatar
Sponsor
what chiltons are you looking at?! 84-85 have leaf springs, 86-95 have t-bar... it wasnt until 96 (well 95.5 if you want to talk about tacomas) that they have coil overs.
Old May 11, 2009 | 08:41 AM
DeathCougar's Avatar
Problem with those junk Chiltons books is they cover a wide year gap, often spanning several generations of trucks. The Chilton I have ever seen just cover 84-95 though, not 96+ (which would be coil sprung)
Old May 11, 2009 | 08:48 AM
scuba's Avatar
The problem with chiltons or haynes is Toyota doesnt make em
Old May 11, 2009 | 09:29 AM
85excab's Avatar
Originally Posted by scuba
the problem with chiltons or haynes is toyota doesnt make em
x 2 !
Old May 11, 2009 | 01:12 PM
Vanman's Avatar
Hey y'all,
Thanks for the replies. Catalog N# 68602 (1989-1996).
Page 8-10: under "coil springs: removal and installation-4Runner"
1. Remove...
2. Disconnect...
3. Remove the shock and coil spring as an assembly.
4. Using a spring compressor, compress the spring...
Needless to say, I though I was screwed.
Thanks for all your help. What manual should I get? Even though I do not do most work, I figure I can still look stuff up.
P.s. That diagram looks much more familiar!
Thanks again!
Old May 11, 2009 | 01:16 PM
904_runner's Avatar
http://www.ncttora.com/fsm/
Enjoy!
Old May 11, 2009 | 01:48 PM
I would assume they were referencing the rear, since the 4Runners are coil sprung rear and they do not have coilovers in the rear.
Old May 12, 2009 | 03:03 AM
Vanman's Avatar
"would assume they were referencing the rear, since the 4Runners are coil sprung rear and they do not have coilovers in the rear."
That is what I thought, yet it is under "Front Suspension."
Darn "Cut and Paste."
Old May 12, 2009 | 10:28 PM
abecedarian's Avatar
That Chilton manual (one of several I have) does reference the 4Runner with coils... which yours doesn't have. You'd actually want to reference page 8-13 Upper Control Arm Pick-up and 4Runner, but unfortunately, no pics. Haynes manual: 92075 89-95 Pick-Up and 4Runner is a better reference for the suspension (and doesn't try to cover the T100, Tacoma and Land Cruiser like Chilton does) but is generally lacking in every other respect compared to the Chilton.
As for a manual- you can look up lots of information here: https://www.yotatech.com/f116
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
