Help, 1986 4runner rear window switch replacements
Old Oct 30, 2019 | 06:25 PM
BbRat's Avatar
Originally Posted by Camric Shultz
I'm showing 5 wires coming out of the 4runner original switch. Only thing I can think is I need both the male and female Previa plug and the three wires are on the back of the male end?
Thanks!
I know this is old but for anyone else looking for an answer to going from 5 wires down to 3 this is it:
The 2 outer wires are for the backlight so you can see up when the headlights are on. The center 3 wires are for up, power and down. The wire closest to the light bulb (round gray circle on side of switch) is for the down, the center is power in and the other is up.
Old Oct 31, 2019 | 02:34 AM
ev13wt's Avatar
5 Year Member
TAKING THE SWITCH APART:
all you need to do is press out the pivot pin. You can see it on the side of the switch (long side). Use something of same dimensions to "press" it out. It not tight at all and easy to do. Then you can take out the internals completely, clean them and put it back together. ( metal rocker, plastic pin with spring inside, outer rocker cover switch. That's it - ya can't screw it up)
I just did this 10 minutes ago and reinstalled, no joke Works great! And it's clean.
Edit: there was a ton of crap in there. I took it apart from the back as well (spread lips and pull out.) and went to town on the case with a dish brush thing and cleaner. Three flushs later it was gtg.
Question: what is the stock arrangement of those center console switches?
UP/DOWN LOCK WIPER
WIPER LOCK UP/DOWN
Anyone know?
Old Oct 31, 2019 | 07:15 AM
BbRat's Avatar
UP/DOWN LOCK WIPER
WIPER LOCK UP/DOWN
Anyone know?
My 88 and 87 were both arranged, starting from the from driver, as:
up/down, lock, wiper.
Old Oct 31, 2019 | 02:07 PM
ev13wt's Avatar
5 Year Member
Well thanks!
It's what I guessed from the wiring lengths.
OCD satisfied!!!
Sleeper
Sep 13, 2012 08:47 AM
tessier88
Sep 18, 2010 03:34 AM
WYrider
May 30, 2010 07:59 PM
jaaydee
12
Apr 2, 2010 08:55 AM
Greatwhite
Oct 14, 2005 03:07 PM
