having a WEIRD starting problem
Old Jan 24, 2011 | 08:50 AM
resurectedvikin's Avatar
going to go out and try to unbolt each end of the fuel filter, and jump the fuel pump to see if its making it through the filter sufficiently!
Old Jan 24, 2011 | 09:08 AM
just loosened off the bolt going from the pump to the filter, and then turn ign on and jumped fp and b+, and NO fuel was coming out of the line, so that leads me to beleive that the pump is shot, correct?
Old Jan 24, 2011 | 09:10 AM
4Crawler's Avatar
SO do you hear the pump running with the jumper in and ignition on? If not, might check if you are getting power to the pump.
Old Jan 24, 2011 | 09:12 AM
power at the pump in the heat was 12v, and the pump actually checked out good....its so weird! intermittent pump problem only when i put it outside in the cold...i'll go check the connection right now again just to make sure its getting 12v at the pump in the cold.
Old Jan 24, 2011 | 09:24 AM
  #25
just checked voltage at pump connector, 12v steady...checked ohms outside in cold and get an open reading....multimeter just displays a 1...so i guess pump is shot, reads good 30-40 in heat, but not outside...weird!! ill change pump and report
Old Jan 24, 2011 | 12:09 PM
  #26
Redneck92's Avatar
Sorry about the out of order post when I pulled it up Half the thread wasn't there. Anyways I know you said you have spark but have you pulled all the plugs and looked at them. That will tell you for sure which cylinder are not running and if they either have spark or don't have fuel. And I have seen pumps to test good and run but not in working order. Hopefully the fuel pump will help but I don't think it's gonna be a cure all.
Old Jan 24, 2011 | 01:12 PM
  #27
Yeah, i fixed the problem of which cylinders werent running already. just the fuel pump issue to go through now, will report on what the outcome is next week!
Old Jan 26, 2011 | 06:23 AM
  #28
it was the fuel pump! all is well now!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Crazychris1871
Jun 27, 2016 10:38 AM
Jnkml
Jul 6, 2015 01:20 PM
