Have to replace false fan pulley bracket, is this what I need?
Old May 23, 2012 | 09:29 PM
stomper4x4's Avatar
So my '92 3.0 cooked the fan pulley bracket bearing thing.
I'm not looking forward to this job
I hear aisin is best so is this what I need?
LINK FIXED!!!!
LINK FIXED
Thanks guys!
Old May 24, 2012 | 02:39 AM
TNRabbit's Avatar
I get nothing on that link.
They're difficult to come by without paying full price, which is SIGNIFICANT. If you can find one from a pick & pull that's in good shape, I recommend that. Aftermarket brands are subject to failure from what I hear.
I put a little motor oil around the bearing on mine whenever I have it out & let it soak in over a couple of hours. Extends the life greatly~
Old May 24, 2012 | 06:24 AM
James Woods's Avatar
I also get nothing from it, the factory ones are $700. When this happened in our 4runner, I tried to press out the bearing and broke the aluminum housing, so I just cut it all out, switched to some shorter belts and got an electric fan.
Old May 24, 2012 | 07:10 AM
chubbydude's Avatar
I have been using a cheap ebay unit I bought years ago and it is still going strong. I did go for an autowrecker unit before that was in good shape, but that siezed up in a MacDonald's drive through one day.
Old May 24, 2012 | 07:39 AM
stomper4x4's Avatar
OK lets give this another shot.
OK try this link
Old May 24, 2012 | 10:14 AM
Lycanistic's Avatar
http://www.autozone.com/autozone/par...er=898128_0_0_
I just replaced mine not too long ago, 115$ at autozone.
Old May 24, 2012 | 10:46 AM
stomper4x4's Avatar
Yeah I saw those but other threads here have complained of the dorman's being no good. Has yours held up?
I was looking for the aisin because if it is better quality, then I would have to do this job less often hopefully.
Old May 24, 2012 | 11:37 AM
Yep thats it.
Old May 24, 2012 | 12:16 PM
Lycanistic's Avatar
No issues outta mine thus far, with anything you buy, there will always be some that slip past quality control. I would venture it a lot better idea than used from a pic n pull.
Old May 24, 2012 | 01:39 PM
rworegon's Avatar
AISIN FBT-006..... yes, that is it in your first link.
For future reference:
http://www.aisinaftermarket.com/PDF_...erenceList.pdf
Old May 24, 2012 | 01:56 PM
Team420's Avatar
IIRC, you cant press out the bearing... There really is no "bearing" Its just the shaft thru the housing, and tapered rollers on the inside, I did manage to press the shaft out, than all the little rollers fell out, and I realized it was not something that could be repaired, and needed to be replaced.
Back when mine seized, autozone did not carry them, and I couldnt find after market ones anywhere... I ended up paying the $700+ the dealer wanted. I would gladly have paid $115 for 1 even if it only lasted a year... the one I paid $700 for only lasted 6 years
Old May 24, 2012 | 02:12 PM
stomper4x4's Avatar
Awesome great reference!
Thanks all
kazuya2416
Apr 5, 2024 02:17 AM
coryc85
Sep 9, 2015 06:24 AM
taller1
Jul 16, 2015 03:00 PM
jon.r
Jul 11, 2015 03:34 PM
zd92655
Jul 5, 2015 04:25 PM
