Got my Blower Motor Resistor, still need a little help!
Old Nov 12, 2009 | 03:47 AM
crafthorse's Avatar
Ok got the BMR for my 91 Yota, installed it, but the AC and Fan only work on low speed. What should I be looking at now, the fan switch, AC button, or what the blower motor itself?
Thanks for any information guys!
Old Nov 12, 2009 | 02:35 PM
Skoalbandit's Avatar
is the resistor installed correctly? generally when those blow they only work on high. check the switch, as well as the relay for the system.
Old Nov 12, 2009 | 05:57 PM
crafthorse's Avatar
Ok, the resistor only installs one way via electrical connector so I know its right. Where is the relay? I would think if the relay was bad it wouldnt work at all. What is the proceedure for cheecking the swith and relay?
Old Nov 14, 2009 | 01:01 PM
check your owners manual for the relay, swap it with another one of the same type. the switch will need to be removed and check the continuity with an electrical meter. ensure you have power in all positions of the switch.
Old Nov 16, 2009 | 06:25 AM
crafthorse's Avatar
Easy enough if you have a owners manual, sorry but I dont, I havent seen a relay for the AC or Heat system. I will check the switch, I I have a gut feeling it is the switch.
Old Nov 16, 2009 | 09:20 AM
cgeorge's Avatar
I just replaced my BMR last week.. my symptoms was that it only would work on HIGH.. and when I removed the BMR it was visually shot.. how did yours look?
Old Nov 16, 2009 | 11:02 AM
crafthorse's Avatar
At first only worked on high, and then it finally stopped all together. Took out to repplace and it was shot as well, the coils finally got hot enough and came apart. I believe now since it only works on low I have a switch problem.
Old Nov 16, 2009 | 11:42 AM
milehigheric's Avatar
then test the switch...there are fsm available on the internets
AudiKev
Sep 3, 2019 02:55 PM
Shoua
13
May 22, 2016 05:19 AM
alimant100
Jan 20, 2016 05:58 PM
PETDOC
Aug 18, 2015 05:29 AM
msane99
Jul 17, 2015 10:13 AM
