glovebox lamp
Old Mar 24, 2020 | 08:16 PM
keycw's Avatar
5 Year Member
glovebox lamp
im not sure how I went this long without noticing that my current 87 runner doesn't have a glove box lamp. im almost positive my 88 dlx had one. there are two unused plugs behind the glove box. anyone know if it is as easy as finding the lamp and the little switch and pluging them in?
Old Mar 24, 2020 | 11:43 PM
RAD4Runner's Avatar
Now I'm curious because I have a DLX but an 86. Where do u see the plugs?
All,
Where is the switch mounted if urs have the light?
Old Mar 25, 2020 | 04:02 AM
keycw's Avatar
5 Year Member
All,
I’ll grab some pics in a bit. They’re just hanging behind the little drop cloth at the back of the box. I couldn’t find that the parts were still available from Toyota but I see a few on eBay.
Old Mar 25, 2020 | 04:09 AM
wallytoo's Avatar
my '88 sr5 doesn't have one, nor do either of my '87 sr5s.
Old Mar 25, 2020 | 07:35 AM
SomedayJ's Avatar
My 2 88 sr5 have it.
Old Mar 25, 2020 | 08:04 AM
wallytoo's Avatar
maybe it's a non-US feature?
Old Mar 25, 2020 | 08:40 AM
SomedayJ's Avatar
I don't know.
Anyway I saw a guy who sells set of leds for old Toyotas, trucks and 4Runner, and the set for the SR5 includes the box glove led, the DLX set doesn't.
He is located in USA by the way.
Old Mar 25, 2020 | 08:42 AM
SomedayJ's Avatar
Here:
SR5
https://www.ebay.com/itm/Toyota-SR5-....c100047.m2108
DLX
https://www.ebay.com/itm/Toyota-DLX-....c100047.m2108
Old Mar 25, 2020 | 08:48 AM
SomedayJ's Avatar
I can dismount one of my 4R's dashboard tomorrow afternoon and take some pics if you need them.
Anyway, you need the right led to fit the glove box light bulb hole. That hole is small and the smallest led I found can't go through it. The original light bulb performs better.
I can take pics of both glove boxes in the dark tonight.
Old Mar 25, 2020 | 08:52 AM
wallytoo's Avatar
it's still generic, in that not all sr5 4runners have the same equipment, ie, neither of my '87s have door courtesy lights. there are sr5s that do not have the inclinometer, but mine do. all three of mine do have the map lights too. so, some sr5s have a glovebox light, but none of my three do.
Old Mar 25, 2020 | 09:04 AM
SomedayJ's Avatar
Maybe your 4R's glove box light bulbs are burnt.
I'm going to upload some pics, give me a sec...
Old Mar 25, 2020 | 09:08 AM
SomedayJ's Avatar
Here:
Old Mar 25, 2020 | 09:16 AM
SomedayJ's Avatar
I was wrong:
You can see the problem with the led, the original light bulb emits(?) light in every direction, and it's needed down.
The led emits light to the front only, almost nothing goes down, that is the reason the original light bulb performs better than the led in that location.
Anyway I had to make the led smaller to fit it in that hole.
Old Mar 25, 2020 | 11:44 AM
old87yota's Avatar
As far as I know, the glove box light was still optional on the SR5 trim level. Actually, there wasn't much that was standard on the SR5 trim level. Many of the "SR5" options still were optional and were not an automatic upgrade when you got the SR5 package.
Old Mar 25, 2020 | 02:44 PM
keycw's Avatar
5 Year Member
these are the unused plugs I see behind my glove box. I was wondering, my truck does not have A/C, would they have anything to do with that? I’m going to poke around some 2nd gen drawings tonight maybe the little light fixture is similar
Old Mar 25, 2020 | 04:12 PM
RAD4Runner's Avatar
Sorry to disapppoint. Most likely AC circuit connectors. Here they are on my 1986 dlx with AC.
Left Side black relay
Right side near blower
Old Mar 26, 2020 | 12:11 AM
SomedayJ's Avatar
In my 88s, the glove box light connector is blue:
Old Mar 26, 2020 | 11:01 AM
RASALIBRE's Avatar
Everything somedayj has posted is present on my 87 sr5, and I can confirm the led replacements not directing light correctly. I Think I remember keyapp stating he doesn’t use leds, but I’ve found leds to be a definite improvement to the electrical system function and light output in every location except the glovebox light.
Old Mar 26, 2020 | 04:11 PM
RAD4Runner's Avatar
Could u guys pls post how and where the bulbs and door micro-switch are mounted? Shud be ez.to find parts and install a custom system wired to any desired fused/switched circuit.
Old Mar 26, 2020 | 04:17 PM
wallytoo's Avatar
not burnt. the fixtures aren't there, nor are the holes for the screws. never equipped with them in my three.
