The GF rolled my Runner!
Old Sep 4, 2012 | 01:51 PM
  #161
SigEp4Runner's Avatar
Originally Posted by HotNotch
not to thread jack, but I noticed your projector headlights. Did you do a retrofit? What projectors did you use
Yes it's a retro, I used the kits that are on eBay but I wouldn't reccomend using those kits. I did this way before the retrofit source had their kits. I have since done 2 retrofits on other cars with the morimoto mini h1s from the retrofit source and the output is way better. Check the link in my sig for my retro for more info, I would check out theretrofitsource.com also since the morimotos are your best option and they only cost $120 for the kit. I was going to change the ones in my runner but there really isn't a point now.
Old Sep 4, 2012 | 06:21 PM
  #162
HotNotch's Avatar
I looked at your retrofit , did the lenses fit over the projector just fine, so its basically plug and play?
Old Sep 4, 2012 | 06:54 PM
  #163
I was lucky when I did the retro and the projectors fit right inside, but I have had other people contact me because their headlights didn't fit the projectors. With the sealed beam headlight you are probably going to have to do some cutting to fit the projector. Over at theretrofitsource forum there are a ton of people doing the retro to sealed beams so you can take a look at how they fit the projectors in there.
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
