gear swap
Old Feb 11, 2013 | 06:39 PM
bob_351c's Avatar
gear swap
I have an 89 toyota pickup with a 5 speed and v6. have gear code G292 i believe. which should be 4.10's. been at the yard and have seen a couple diffs with the code g254 so 4.556 gears and 4 pinion design. I assume mine is also 4 pinion since its a v6. anyways should i have any issues putting a complete 4.556 3rd in place of my stock 4.10's? both front and back diffs of course
Old Feb 11, 2013 | 06:53 PM
niall's Avatar
No problems, that will work.
Old Feb 12, 2013 | 02:46 AM
racersg's Avatar
X2.
It will work just fine. I have done the exact swap myself for another guy.
Good luck.
Old Feb 12, 2013 | 11:11 AM
Stuwy123's Avatar
G292 is a 4.10 with 2 pinion. FYI
The number of pinion's doesn't affect the install.
Old Feb 12, 2013 | 05:02 PM
bob_351c's Avatar
thanks for all the replies, was pretty sure it would be fine, just wanted to make sure the housing would work especially with the 2 pinion vs 4 pinion deal. btw are the 4.556 gears desirable or are they too common to be worth anything? the yard has 3 sets and a sale coming up. could save them from the crusher and maybe make a little off them/ spare parts
thanks, i read that the v6's are almost always 4 pinion and if the door code says otherwise its a common missprint. not that i care too much since il be switching it out.
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
