Gauge Cluster
Old Aug 6, 2014 | 09:33 PM
weaselman's Avatar
Gauge Cluster
what would cause every gauge on my cluster to stop working except for speedometer. all the lights work except for the check engine light work.
87 turbo 4 runner. anaolg sr5 cluster.
evetything was working and then the truck sat for 2 weeks and then it stopped working.
Old Aug 7, 2014 | 04:10 AM
mct75's Avatar
Check your fuses? The gauges aren't getting power or ground. Each gauge is pretty separate, needing only power, ground, and the resistance from the sender.
Does the oil gauge work? It ONLY has a +12V and sender signal, so if it's the only thing working, you have a ground problem.
Old Aug 7, 2014 | 08:15 AM
Terrys87's Avatar
Mine was the Reverse light rubbing the tranny https://www.yotatech.com/forums/f199...l#post51746688 and blowing the engine fuse.
Old Aug 7, 2014 | 10:28 AM
weaselman's Avatar
All the fuses are good. The truck still runs. And none of the gauges work. Not even the oil gauge.
Old Aug 7, 2014 | 11:03 AM
kcaudill's Avatar
Bad ground(s)
Old Aug 7, 2014 | 11:48 AM
weaselman's Avatar
it makes sense but i just dont get how a ground can stop working and the truck only sat for 1-2 weeks. i drive a tow truck for a living so it sits for a period of time.
where are the ground for the inst cluster? under the dash? left or right side?
Old Aug 7, 2014 | 03:05 PM
Terrys87's Avatar
I clean the ground next to the fuse box in the cab. I clean the the body down to bare metal and give the ground cable a good scrubbing with a wire brush. Not sure if this is the actual ground that works with the cluster but it is worth a shot.
Old Aug 8, 2014 | 07:55 PM
weaselman's Avatar
thank you.
Old Aug 9, 2014 | 07:06 PM
weaselman's Avatar
here was the problem. no power to any of the gauges.
repaired!
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
