Gas gauge reading sporadically or not at all
Old Aug 3, 2012 | 11:00 AM
waskillywabbit's Avatar
Lip goes on the outside of the frame but you really need to weld inside too. No way to do it right IMO without dropping gas tank.
Like I said, I'd rather NOT get dead.
:wabbit2:
Old Aug 3, 2012 | 11:09 AM
OrRunner's Avatar
Oh, now it really makes sense, For some reason, I was thinking the lip went to the outside...DOH then I would be on here asking why my springs don't line up...Man, good thing its friday!! Thanks again!
Old Aug 3, 2012 | 11:13 AM
Correction. Lip goes on outside but you really need to weld inside too. Regardless...gas...welding...boom...I am allergic to exploding.
:wabbit2:
Old Aug 3, 2012 | 12:03 PM
sbagdon's Avatar
Originally Posted by waskillywabbit
Filled up yesterday. Good for about 50 miles and it started being squirrely for another 10 miles. It would register up and down from 3/4 to nothing and back again.
Sounds like a bad sending unit. At least I think it can be pulled with little trouble and swapped.
Thanks for the feedback guys.
:wabbit2:
Sounds that you've ordered a new sending you, yet if you get bored before install, try this...
Run the tank to 1/2, and park on an exterme incline. Bet the gauge will go crazy, as it walks up/down the level sensor shaft, and find the bad spots on the shaft.
We had a van that when parked on a specific driveway, would go from 1/8 to empty (and even loose fuel pressure if too low).
Old Aug 3, 2012 | 12:51 PM
  #25
dropzone's Avatar
Fossilized
Originally Posted by DeathCougar
Sending unit for sure.
The FSM outlines the testing procedure, I can get that for you when I get home if you want.
He should have known where to find the testing procedure
www.ncttora.com/fsm
No special tools needed other than your brain and search
:wabbit2:
Old Aug 3, 2012 | 12:56 PM
  #26
Resistance for testing of sender gauge.
Looking for someone who had a similar experience and discovered what their solution was in fact. I can pull it and test either/both.
:wabbit2:
Your reading comprehension is dazzling :fo2:
:wabbit2:
Old Aug 3, 2012 | 01:00 PM
  #27
OrRunner's Avatar
:wabbit2:
Correction noted, lip to the outside, but weld the inside also, Thank you sir!
Old Aug 3, 2012 | 01:01 PM
  #28
scope103's Avatar
http://www.ncttora.com/fsm/1990-1995...2/troubles.pdf (pages 49 and 50).
The actual gauge is a "hot wire ammeter," so you can't really test it with a "voltage generator." It's measuring, more or less, current through the sender and the gauge combined.
That doesn't mean someone couldn't measure the voltage drop across the gauge at various fill levels. If you had that you could hook up a $4 digital panel gauge and you'd have a digital fuel level gauge. But it won't help much for diagnosing the problem in this thread.
Old Aug 3, 2012 | 01:49 PM
  #29
wyoming9's Avatar
Red face
I don`t want you dead either not just yet any way
It might be interesting getting the lines off the pump bracket.
Old Aug 3, 2012 | 02:29 PM
  #30
Originally Posted by wyoming9
I don't want you dead either not just yet any way
Thanks
Already popped off the lines when I lined the tank.
:wabbit2:
Old Aug 4, 2012 | 01:45 AM
  #31
wyoming9's Avatar
Red face
the joys of living out side the great rust belt .
One only needs to watch out that the goats don`t eat the wiring harness!!
Old Aug 4, 2012 | 05:40 AM
  #32
Goats don't have a key to the shop and no shop goaty doors
:wabbit2:
Old Aug 11, 2012 | 03:32 PM
  #33
Swapped in a new Toyota sending unit.
:wabbit2:
Old Aug 12, 2012 | 01:06 AM
  #34
wyoming9's Avatar
Red face
So you got this sorted!!
See this is what happens when you go on to short of a vacation!!
You need another few weeks come back after Labor Day
Old Aug 12, 2012 | 03:04 AM
  #35
93toyota4x4's Avatar
I have the exact problem with my truck and I have a good sending unit in my parts truck but the rust doesn't want to let it go. Any ideas how I can get it off without ruining the tank?
Old Aug 17, 2012 | 05:12 AM
  #36
PB Blaster. Rust kills.
After a week and another fill up today the new sending unit has fixed the gas gauge issue
:wabbit2:
Old Jul 23, 2014 | 08:30 AM
  #37
Connor G's Avatar
mine did a similar thing. mine would work fine till a quarter tank then hold there for a while. then drop to e for like 10 seconds and then go back to a quarter and stays there to you run out of gas on the road if you dont notice the drop. I replaced the sending unit and it appears to fix the issue.
Old Jul 24, 2014 | 01:56 AM
  #38
Terrys87's Avatar
What happens is the wiper on the float assembly eventually rubs the wire which is fine as a human hair until it breaks the wiring. Everytime I have seen it happen, it is always at the bottom of the float which makes sense as it is the part that will get the most rubbing.
May not be able to see it to well but here is an example.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
