fuel pump
Old Feb 24, 2006 | 07:07 PM
87rustbucket's Avatar
fuel pump
my fuel pump in my 87 22r motor isnt really workin. It will start, run for about 2 seconds then die. Is there any way to trouble shoot the pump or to fix it? thanks....kev
Old Feb 24, 2006 | 07:20 PM
tntoyota22's Avatar
take the line going to the carb off and turn the engine over , gas should come out.
Old Feb 24, 2006 | 07:29 PM
i tried that and it just sputters out-no steady flow
Old Feb 24, 2006 | 07:31 PM
tntoyota22's Avatar
ur pump is fried or ur filter is clogged bad
Old Feb 25, 2006 | 06:33 AM
V_Runner's Avatar
Banned for stupidity
that's what you get for not putting any drygas in the tank when it reaches 0-10 at night all winter...now look what you have to deal with...
Old Feb 25, 2006 | 08:31 AM
u get those temps to and u dont put dry gas in!!!
Old Feb 27, 2006 | 12:18 PM
V_Runner's Avatar
i put dry gas in 2 or more times a year...winter,most of the time...and summer...take that Kev
Old Feb 27, 2006 | 03:16 PM
im so pissed. I started to take off the pump. I loosened the first bolt partly-no problem. Then the second. It started and about 1 turn in it snaped in half Now i not only have to replace the pump but also must have the remaining bolt drilled and taped. Just my luck.
Old Feb 27, 2006 | 05:23 PM
soulfly's Avatar
get some bolt extractors/easy outs they are cheap
http://www.irwin.com/irwin/consumer/...rwinProd100318
gohawks's Avatar
Here you go: http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Maybe that will help?
Bookmark 4Crawler's website, sooner or later you will need it, he knows it all!
Old Feb 27, 2006 | 05:52 PM
i got a 22r not a 22re!
Old Feb 27, 2006 | 06:01 PM
soulfly's Avatar
Well I guess it sounds like you might just have to get yourself a 22re
Old Sep 27, 2006 | 08:37 AM
4rnr's Avatar
Anyone have a better explination as to where the connector is that must be jumpered. I have a 3.0 so my ˟˟˟˟˟ is reversed. I have a similar looking connector on the pass side It leads to a module that is heavily heat sinked. Is this the connector. Im trying to trouble shoot a starting issue in my 88 4runner. It takes a few sec of cranking and even then sonetimes it will stutter, requiring me to continue to crank until the engine fully turns over.
I see now that what I thought was the correct connector is not. So where is this thing.
Old Sep 27, 2006 | 10:11 AM
4rnr's Avatar
Never mind I found it. mine IS in the diagnostics box. I jumpered it for less than a sec and fuel GUSHED out of my return line (which I unhooked) so Im thinking my FP is good. I think I have an air leak, probably the intake plenum gasket which I replaced last week when I replaced my leaking press. regulator. If thats the case I dont see the harm in letting it be a little leaky as long as I have this mod.
BTW what will happen if I leave the ignition on while not running the engine. forcing the FP to run. Will it just flow back via the return. I know the chevys have that loud a$$ FP that comes on with the ignition but eventually shuts off. Just checking.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
