fuel pickup lines?
Old Jul 25, 2010 | 06:23 PM
stackedyoda's Avatar
fuel pickup lines?
does anyone know somewhere besides the dealer where i can get the whole pickup line assembly, mine is completely rotted out and i hate going to the dealers
Old Jul 25, 2010 | 06:25 PM
Tofer's Avatar
Sponsor
"hey there baby... you look explosive" - fuel pickup line
Old Jul 25, 2010 | 06:27 PM
Tofer's Avatar
Sponsor
try someone parting out a rig on CL or here.. or try ebay.
Old Jul 25, 2010 | 06:34 PM
myyota's Avatar
Try the yota yard in Denver, i bet they would have one. Ive ordered stuff from them before and they have good service.
Old Jul 26, 2010 | 09:06 AM
BigSwole's Avatar
hey bud im looking for one too, i have been searching and searching for months to no avail. if i happen to stumble across some i will let you know,
everywhere i have been searching only offers the lock ring or the fuel pump itself...
good luck, if you find em before me let me know...
which type of vehicle are you looking for one? (2wd 4wd ext cab re cab) what size is your tank?
Old Jul 26, 2010 | 09:39 AM
BigSwole's Avatar
http://www.partswebsite.com/pagetoyo...n=6&type=parts
i found this, it has no picture, but it was the first time ive found it online...
idk about you but im not paying 300$ for the assembly
here is an exploded view of the 2wd setup,
http://www.partswebsite.com/pagetoyo...15&catid=30197
Old Jul 26, 2010 | 10:42 AM
Wes94's Avatar
you can probably buy 25' of line, a flare tool and a bending tool for half the price of a pre-bent line. I just did this and it does require a lot of patience but is rewarding. The flare tool and bending tool can also be used on other sized line like for brakes and if you haven't replaced those yet and your fuel line is rotten then i bet you will need to soon.
Also i ended up having to replace the "fuel pump bracket" because the piece of line that is part of it and goes into the tank was also rotten. i bought mine from fredhaastoyotaparts.com. it came in today and i will be putting it on tonight. I also replaced the fuel filter while i was at it.
If you have any problems dropping your tank or anything feel free to ask. i actually found it wasn't as difficult as people on here make it out to be.
*After reading back through i realize you only need the part i ordered, I paid $145 for it and it was by far the cheapest i could find. i wouldn't waste my time putting a used one in. it is too easy to crack old lines when trying to break fittings loose.*
I still recommend you do new lines up to the flex line in the engine bay to save yourself future headaches.
Old Jul 26, 2010 | 10:45 AM
BigSwole's Avatar
i was assuiming he was talking about the fuel pump assembly lines? im in the same boat and cannot find those for the life of me...
dropping the tank is super easy, especially when there is a drain plug on the thing.
Old Jul 26, 2010 | 10:53 AM
Wes94's Avatar
http://www.fredhaasparts.com/ cheapest place i could find. shipping wasn't bad either. fast shipping too
get the part number from diytoyota.com or from your dealer (use your vin to make sure it is the right one) and search for it on there. If you just search the categories on the website you won't find it by itself.
Old Jul 26, 2010 | 11:17 AM
Wes94's Avatar
I believe this is exactly what you are after: http://www.fredhaasparts.com/partloc...&siteid=214592
dang the link broke, this is your part number 23206‑35280 just type it into the search
Old Jul 26, 2010 | 11:19 AM
BigSwole's Avatar
bad link wes
Old Jul 26, 2010 | 11:48 AM
Wes94's Avatar
^yes i know, thats why i edited and put the part number below. just copy and paste that part number into the search box that you get from the link. the cost is $131 and i paid $14 to have mine shipped to northern maine.
here is the part number again for the 22re fule pump bracket assembly 23206‑35280
Old Jul 26, 2010 | 12:52 PM
BigSwole's Avatar
can you upload a picture of what you recieved?
Old Jul 26, 2010 | 02:50 PM
well i'm kinda thinking of taking the whole top piece out, cutting all the lines off the top, and cutting some away from the bottom, drill the hole out in the top, run brake line inside the tank and connect all the previous tube and new tubes with rubber fuel line, and taking them back out the top and bending them all the right way, then epoxying them into place
Old Jul 27, 2010 | 04:13 AM
Wes94's Avatar
I didn't take any pictures and the part is already installed in my tank. it is the piece that has 2 steel lines (one feel line from the pump and one return line) going through a round metal plate that has a bracket attached to it for the fuel pump. the pigtail for the fuel pump is also a part of it.
I tried doing this but welded the the new line into the plate. the line was too thin to tig weld and i ended up burning it to thin and it broke when i tried to tighten my fittings. Epoxy may work better (obviously make sure it is something that can handle gasoline) but good luck not breaking the seal when you tighten the fittings. Also getting the bends and length of that piece perfect so you can connect it to your hard line through that little hole under the seat is not easy. In retrospect i wish i had spent the $150 on the part before i spent 6 hours trying to mickey mouse a new one I bet the return line in that part is just as rusted as your feed line from the pump so you might want to replace that while you are at it. Good luck!
Old Jul 27, 2010 | 01:20 PM
i think i'm just going to go to the dealer and buy a new one, i'm a little weary of buying one on the net without a diagram to make sure its the right part.
Old Jul 28, 2010 | 04:50 AM
Wes94's Avatar
If you have money to burn go for it. i didn't so i talked to my local dealer to make sure i had the right part number and then i ordered it. fredhaastoyota is a toyota dealer in Houston. I also talked to them on the phone and they were very helpful. The part i got is a genuine Made in Japan Toyota part, exactly what your local dealer will charge you $300+ for. i don't know why these guys can sell for cheaper but i am very glad they did. Wearyness is probably how people who overcharge for parts stay in business.
Old Jul 28, 2010 | 06:24 AM
aviator's Avatar
Fuel Pick-up lines...
Howdy Ma'am you need some gas?
Hey baby did you run outta gas?
Hey girl my tank needs some lovin' can you help me?
IK this was'nt helpful but I saw the title and I could'nt stop myself.
Keep smiling...
Old Jul 28, 2010 | 11:39 AM
might not be on topic, but that's the stuff usually makes my day a little better
Old Jul 28, 2010 | 12:01 PM
Wes94's Avatar
You runnin hi-test?
If you were a car i'd only run supreme in ya.
Baby you are one high octane lady!
Now that our tanks are full.. you wanna get an ice cream.
Maybe it's just the fumes talking but i think i'm in love with you..
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
zd92655
Jul 5, 2015 04:25 PM
