Autopathetic transmission
Old Jul 28, 2010 | 08:16 AM
DrCreosote's Avatar
Since I'm doing a rebuild on my 3vze, I thought I might address the autopathetic transmission behind it. Generally, this has been a good gearbox and has only one little problem, though it can be very annoying.
Whenever the outside temperature is below about 55 degrees, it has trouble getting into and staying in overdrive. Around town, it's no big deal, but when I make that yearly drive from CA to UT for Christmas, it is frustrating beyond words. I've tried to fix it with additives, and if that works, it only works briefly. I did an oil-filter change and that did not seem to change its behavior much at all.
This thing works flawlessly during the hot part of the year, which is most of the year, so it doesn't sit in my mind much.
So has anyone else experienced this problem or one similar to it? I have a clear picture in my mind of a weak valve spring or a determined deposit of crud and I could fix it maybe with a shift kit (if they make such a thing for this gearbox) or by just removing it and cleaning it up.
I've also not ruled out putting in a manual transmission, though I might prefer to just replace the vehicle with one set up that way already.
This truck is absolutely stock with the exception of the Pioneer speakers I put in it two years ago.
Old Jul 28, 2010 | 08:20 AM
Fink's Avatar
Model, year and mileage?
Fink
Old Jul 28, 2010 | 08:54 AM
Marc's Avatar
Make sure you have the correct thermostat.
Old Jul 28, 2010 | 01:05 PM
DrCreosote's Avatar
Fink
1990 4Runner SR5 V6 208,000
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
