front spindle question
I searched the forums first for part number cross reference and found nothing... Here's my question I have a 1994 2WD, and I'm looking for a set of stock front spindles. Will the spindles from a 1987 2wd work ? From what I can find here it's the same part #:
1994
http://www.toyodiy.com/parts/p_U_199...DEAB_4802.html
1987
http://www.toyodiy.com/parts/p_U_198...-KRA_4802.html
1994
1987
are you positive? 2wd now...
I'm pretty sure 4wd's are, but I have no knowledge about the 2wd
the brake caliper mounting holes look a little further apart on the pics of a 94 spindle, maybe because of a brake upgrade?
I dunno...
I dunno...
Toyota has different part numbers for the spindles through the years.
However, they use the same size brake rotor and caliper from 84-95, assuming you match 4cyl base to 4cyl base. The DLX and SR5 models use larger brakes than their predecessors.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
icentropy
Jul 14, 2015 10:23 AM
