First Post! Just Got a 2nd-Gen 4Runner! Suggestions!
It's a stock bumper with a Westin Pushbar attached to it.
It sounds like you have a great start lined up. You will be very pleased with the Bilstein/Downey combo. Headers are supposedly the single best thing you can do the 3.0 engine to get a little more power out of it. Also it eliminates the restrictive crossover that has led to many #6 cylinder burnt valves.
Ok, I went out and crawled around in the snow for a while and this is what I came up with:
Driver Side
Passenger Side
Cheap camera trick making me look over 6ft tall.
I like the look a hell of a lot better and for a half-hour of wrenching its definitely worth it.
-Sam
Driver Side
Passenger Side
-Sam
It look so much better without those boards. My 91 4runner was green. My 92 is red. I will post up some pictures or do a search and you will find all kinds of great looking rigs to get some ideas from.
#25
#28
Here's what I've done, and I don't regret any of it:
33x10.50's
Ditch running boards
Dented the crap out of my rockers
Sliders
Budbuilt skidplates
Gears + ARB lockers
Rear bumper
Broke out rear glass
1/4 exo to protect glass
Front bumper
33x10.50's
Sliders
Budbuilt skidplates
Gears + ARB lockers
Rear bumper
Front bumper
#32
EDIT: Figured it out: http://www.central4wd.com/inventoryd...;folder%7C5510
-Sam
#33
After all the reading and searching I've done on these forums I realize I might as well just stick with the stock 3.[0|slow]. Yes, it's a slow motor but they run onwards of 300,000 miles and I need it to do so. So you can chalk me up there with the "F* IT" crowd in regards to the 3.0 before I've even touched the airbox!
-Sam
-Sam
#38
Go to your local car parts store, and ask for a can of engine restore for the engine type you have (IE: V6, V8, etc.), then pour it in to your oil reservoir and let your engine run until the clicking, tapping, or other noise stops. If that doesn't fix it, then you might have an issue that won't be fixed by it.
#39
Restore stuf works wonders... also will help build up a bit of compression by reducing/preventing blow by caused by scored [old] cylinder walls. Actually improved the performance and MPG on my engine. {which it would of course LOL}
#40
-Sam
MMA_Alex
25
Apr 18, 2017 05:07 AM
