Finally getting A Yota!
Old Oct 24, 2009 | 07:26 PM
  #101
CHEEZBURGER's Avatar
Originally Posted by Kiroshu
Does the truck even spin over?
It cranks over and even wants to fire but it doesn't start, the longest it pretended to run was about 1 second then just crank and crank, I'll get it though, I'm sure once I clean up the injectors and the pump, and tune her up she will be fine, Then I just need to find a cheap 22r to build so I can drive this one around
Old Oct 26, 2009 | 10:02 AM
  #102
Windsor's Avatar
Be sure to check the drivetrain fluids (trans, xfer, both diffs).
I ended up eating a transmission rebuild because I did not check that (the transmission gave out before I even got it home).
Old Oct 26, 2009 | 10:12 AM
  #103
I'll be checking that all out after I get this stupid gas tank out, I'm really happy it has a drain plug because it was almost full, I got a little over 16 gallons of stinky gas out of it and now my garage reaks and it's coming into the house
Does anyone know how or where to dispose of old fuel?
Old Oct 26, 2009 | 10:38 AM
  #104
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Use it in your lawn mower or contact your local garbage company, they should be able to tell you where it needs to go.
Old Oct 26, 2009 | 12:21 PM
  #105
Just found out I need to take it to Boulder, they have a hazardous material place there, I also picked up my first library card and got a chilton and a haynes for it so maybe I can get unstupid about what I'm doing
Old Oct 26, 2009 | 07:29 PM
  #106
ScottyC's Avatar
Weak spark reminds of a bad ignitor(screwed into the top of the coil)
Old Oct 26, 2009 | 07:45 PM
  #107
Really, I'll have to check into that a little more, maybe I'm too old american car but I thought that weak spark off of the coil wire meant a bad coil, all stuff to check into, I just can't wait to get my next payment for my old car so I can buy crap
Old Oct 27, 2009 | 07:46 PM
  #108
ScottyC's Avatar
These style coils usually don't go bad. The ignitor is a different story. The ignitor will send a signal to the ECM that will tell the injectors to fire. If you have weak spark from the ignitor, then you will have no fire to the injectors and it won't start.
FWIW, they are NOT cheap, so hit the pic and pulls and get the same one. Write down the part number and take it with you.
Old Oct 27, 2009 | 08:08 PM
  #109
85yota4x4's Avatar
dig a hole in youe neighbors yard then dump it in
Old Oct 27, 2009 | 08:09 PM
  #110
broyota's Avatar
Thats an 87. Only 87 came with that style grille and the Clinometer/altimeter. I had one just like that.
Old Oct 27, 2009 | 08:10 PM
  #111
broyota's Avatar
Burn it
Thats what I would do
Old Oct 27, 2009 | 10:36 PM
  #112
Armalite's Avatar
x2 for burning it
fire is always fun.
Old Oct 28, 2009 | 12:52 PM
  #113
As much as I would love to burn it, I'm gonna be a good boy and dispose of it properly
Old Oct 28, 2009 | 01:58 PM
  #114
cgeorge's Avatar
flame on!!!
Old Oct 28, 2009 | 02:11 PM
  #115
Kiroshu's Avatar
I just came out of a serious issue with my ignitor and it happened to be the wire running arcoss from the ignitor over the valve cover that had broke and was grounding out to the valve cover and the truck would not run...... it was very frustrating make sure that wire is not broke or nothin.... if its been sitting so long beat on the ignitor a bit with a screw driver or hammer... not too hard.... someimtes the little electrical parts in there freeze up and stick... coils usually last a long time but they go out every so often..... fuel filter i would change for sure since its been sitting so long.... check pump with a battery to see if it works or try and start the truck with the inspeaction cover for the pump off and see if you can here it running durning cranking time.... if not then its bad prolly....
runnermedic
13
Sep 21, 2015 05:20 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
Boomer8404
Sep 10, 2015 09:01 AM
anndel
Sep 10, 2015 08:50 AM
