Famous "high idle/surge" culprits!
Old May 23, 2008 | 10:40 PM
  #301
abecedarian's Avatar
He tries to talk but it's more of a whisper. Earlier it sounded like he said '91 fix the compression'
Old May 23, 2008 | 10:50 PM
  #302
thook's Avatar
Going by that pic, I'm sure he's gorgeous, Kirk.
I've got two African Greys (one's named Thook.....where I took my username from, incidentally....rhymes with spook), two Amazons, two Cockatoo's (one Umbrella and one Moluccan), two conures (one sun and one green cheek) over a dozen cockatiels, parakeets, and assorted other types.
The Cockatoo's are the loudest mf's on the face of the planet. Uggh! But, we (my wife and I) have an animal sanctuary. So, you just kinda live with it...lol!
Oh, and they bite really f'n hard, too!
Old May 23, 2008 | 10:54 PM
  #303
thook's Avatar
Ah ha! I'll bet he did!
You ever experience telepathy with your bird?
Old May 24, 2008 | 10:56 AM
  #304
91Toyota's Avatar
LOL...I bet
Old May 24, 2008 | 01:11 PM
  #305
91Toyota's Avatar
So, today its like 85 degrees and its sunny. Went for a drive. Went to town and in town it idles at 750. On the way home I drove 50mph and had a REALLY light foot. It started surging like hell. It was idling at 1600 rpm fully warmed up...wtf?? This is getting to be REALLY annoying. I'm actually getting to the point of sick of it.
Old May 24, 2008 | 01:16 PM
  #306
i'm going out on a limb here...
I think something's wrong.
What all have you done to it again?
Old May 24, 2008 | 01:21 PM
  #307
91Toyota's Avatar
LOL...I've done too much. Hell, after I've replaced all the sensors and wires I'll have a brand new truck
Do you have any idea...or are you stumped too?
Old May 24, 2008 | 01:28 PM
  #308
well let's see- it idles fine then it doesn't.
vacuum leaks, water air temp sensors,
sticking throttle, return spring, cable or pedal?
when it's idling high, pop the hood and see if you can put a bit of pressure on the throttle and get it to idle down.
Old May 24, 2008 | 04:22 PM
  #309
91Toyota's Avatar
Well, it seems like it only idles high like that on hot days So, I would assume its something electrical wise...like a sensor or something.
Maybe since its warmer it expands and sticks...who knows
I'll check some of these things
Old May 24, 2008 | 06:10 PM
  #310
just a 22re's Avatar
wow i only read the last page but so far its just like my old 7 honda civic crx si i had it did this same thing when ever it wanted to guess what it was the butterfly yep so i took it off cleaned it filed it just alil bit to get the burs off and put it all back together and what do you know its lke drive a gocart again yeah do what he said get it to go crazy and stop pop that hood and try and close the butteryfly if that dont help then you need to look into a intake gasket maybe just my .4 cents
Old May 24, 2008 | 06:21 PM
  #311
91Toyota's Avatar
Yeah, new gaskets
I'll be taking it apart again anyway...hopefully I get my job in two weeks too
Then, I'll get a discount on auto parts
Old May 24, 2008 | 06:55 PM
  #312
but yet again you think it could be that number 3 messing with ya? or is that fixed and from what you said sounds like you found it aye?
Old May 24, 2008 | 07:42 PM
  #313
heya 91Toyota... did you adjust the valves on the truck?
Old May 24, 2008 | 07:53 PM
  #314
91Toyota's Avatar
Yeah...it could be. Although I didn't have this problem 5k miles ago.
I was an idiot and took it apart to fix it and I got to taking the pan off and put everything back together really fast. And left the problem alone. Got the head back from the machine shop and slapped it on. I've had coolant leaks, injector leaks, over heating, and surging. Just down to the idle and the compression
Yeah, as soon as I put the head on. Forgot to attach the egr exhaust hose and it sounded like the valves were horrible. Put that back on and the valves were fine. I went ahead and adjusted them again after I got everything back to normal. Why, should I adjust them again?
Old May 24, 2008 | 08:22 PM
  #315
I couldn't remember as was too lazy to read over the thread again.
Old May 24, 2008 | 10:18 PM
  #316
91Toyota's Avatar
Don't blame ya! I don't want to read it all over again either
But I might have too
Old May 24, 2008 | 10:20 PM
  #317
91Toyota's Avatar
Also, what causes my thermostat problem? Why would I all of a sudden need to drill a d@mn hole in it to get my truck to work.
The problem is the thermostat wouldn't open till it reached about the red zone. Then I drill a hole in the thermostat and it works fine. Wonder if I drilled too big of one
Old May 25, 2008 | 07:12 AM
  #318
possibly your hole is too big.
the t-stat I've got in my 88 and 91 both have little jiggle valves in them. and both work fine.
4crawler touches on this on his page http://www.4crawler.com/4x4/CheapTricks/index.shtml open the page and search on it for the word overshoot and start reading.
also, thook wrote about it in THIS thread at the top of page 7 https://www.yotatech.com/forums/f116...l#post50819214
Old May 25, 2008 | 08:28 AM
  #319
91Toyota's Avatar
Yeah, I was hoping for you to explain cuz I'm too lazy right now. Well, sort of good news. I'm getting rid of my junky subaru with no engine in it for a 22re that is complete with a bottom end noise. I'm hoping to rebuild it in my garage and when it comes time (this summer) I'm slapping that bugger in there
Old May 28, 2008 | 11:02 AM
  #320
91Toyota's Avatar
Alright, put a bunch of oil into #3 cylinder and my compression went up to 235psi!!! WOW!!! So, it must mean my rings are bad...right? Unless oil can fix valve leaks or something like that??
