Ext cab bed and short bed
Old Jan 8, 2012 | 10:25 PM
norcal98's Avatar
Pretty much what the title says. Is the short bed and the ext cab bed on a 93 pickup the same? IE, can I find a wrecked standard cab truck with a good bed and put it on my Ext cab truck that has a hammered bed from too many over grown roads?
Old Jan 8, 2012 | 11:32 PM
scuba's Avatar
Yes. 6 foot bed on both.
Old Jan 9, 2012 | 07:40 AM
norcal98's Avatar
Thanks
Thanks. I knew the ext cab 2wd ones were the same, but for some reason thought the ext cab beds were different and maybe had difffernt mounting location. That gives me a lot more choices . Also means I passed some good ones up already, live and learn.
Old Jan 9, 2012 | 04:05 PM
Stuwy123's Avatar
I kind of doubt they are the same.
There's a specs manual floating around online with all the frame dimensions.
This will give the body mount positions for the bed and will tell ya if they are the same/similar or not.
Unless someone has owned both or can give you a straight answer.
Old Jan 9, 2012 | 04:18 PM
slacker's Avatar
they are the same
http://www.toyotafiberglass.com
Old Jan 11, 2012 | 09:38 AM
norcal98's Avatar
Thanks for the link. Says you have a fiberglass bed on your 86. Whats the advantage out of curiosity? Are the easier to fix?
Old Jan 11, 2012 | 12:05 PM
highonpottery's Avatar
^it won't rust
Old Jan 11, 2012 | 04:02 PM
slacker's Avatar
I've had mine on my truck for 12 years now .. other then being rear-ended
($3000.00 damage to the ford ) , broke my glass gate , I still havent fixed it but the insurance company did give me a G note . Other then that it still looks as good as the day I put it on
Old Jan 11, 2012 | 05:29 PM
norcal98's Avatar
I guess the rust issue was so obvious I missed it, but it makes perfect sense. I was just curious if it was easier to fix or to knock dents outs. My current bed is hammered and imagine when I replace it, the next one will end up the same eventually.
Thanks for the replies
88sasturbotoy
Jan 30, 2026 01:57 PM
young buck
18
Aug 27, 2018 02:40 PM
pyramid
Jul 29, 2015 06:53 AM
Backcountry411
Jul 24, 2015 08:06 AM
elwood73
Jul 5, 2015 07:07 AM
