Exhaust manifold compatability?
Old Apr 9, 2007 | 10:36 AM
Paladin's Avatar
Hey guys,
I have an 89 4wd with 22RE EFI. I have a cracked manifold and need to replace it. The question is. What is the difference in the manifold for an EFI or carb'd engine? Are they interchangeable?
Thanks
Old Apr 9, 2007 | 01:26 PM
Paladin's Avatar
I guess the real down and dirty question is...
Is there any reason this will not go on my truck?
http://cgi.ebay.com/ebaymotors/EXHAU...spagenameZWDVW
Old Apr 9, 2007 | 02:44 PM
Bill's Avatar
should fit. I'm pretty sure the difference is in the intake side, not the exhaust.
Old Apr 9, 2007 | 08:27 PM
Elton's Avatar
welcome to yotatech ...84 and older uses round exhaust ports and 85-95 uses pear shape ports and the 22r and 22re are pretty much them same
Old Apr 9, 2007 | 08:41 PM
DeathCougar's Avatar
depends on where the O2 sensor is. You could use one that has a hole if you plug it, but if you need the hole and it doesn't have it, you will have to find a manifold that has the o2 hole.
Old Apr 10, 2007 | 09:06 AM
Bill's Avatar
Normally yes, but oddly enough the 22RTE turbo manifold uses round ports, while the head still has the pear shape. little bit of UFI
Old Apr 10, 2007 | 09:12 AM
drew303's Avatar
22r and 22re use same exhaust manifold.
you can get the gaskets at Napa. The manifold gasket is around $30 and the head pipe (2 on the manifold, 1 @ the cat) for a few bucks each.
Old Apr 10, 2007 | 02:06 PM
Paladin's Avatar
Hey thanks guys,
Really appreciate all of the info. Just found this forum.
WOW! What a wealth of info.
Old Apr 10, 2007 | 02:15 PM
dijlop's Avatar
Originally Posted by Paladin
Hey thanks guys,
pal, u aint seen nuttin yet. lol
justdifferentials
14
Jun 11, 2017 08:36 PM
Obmi
Sep 10, 2015 03:36 AM
idadan208
Sep 7, 2015 09:06 AM
May-39
Sep 6, 2015 01:05 PM
