Exhaust fell off this morning... Anyone know the stud size?
So apparently my exhast fell off this morning... Was driving up to the corner store to get me some coffee and all of the sudden I noticed my truck was sounding loud as hell. I thought GROOVY! As I was walking back to my truck some highschool kids came up to me holding what was left of my exhaust train.
I guess I lost the nuts that hold it to the manifold, and the hangers just couldn't hold it.
SO... Does anyone know off hand what size these 3 studs or nuts are?
I still have the studs, so I just need to find out the size so I can go pick up some nuts (speaking of which, what kind of nuts are they?) at the hardware store.
Can't for the life of me think of the name of that place. It's post-manifold pre-cat. GRRRRR That's gonna piss me off all day.
I at lease plan on being semi productive today. Gonna weld the front and rear spider gears (pissed the hell outta me yesterday while offroading), chop those body mounts that get in the way of front leaf's shackles for more flex, and probably build a front bumper.
No beer today. Super hungover...
10mm shank x 1.25 thread pitch on the studs.
I believe your asking about the muffler shop?
Who put this truck together, Clint? (Prior to your modifications, of course.) First, it's the oil pan bolts. Now, it's the exhaust pipe....lol. Have you considered going over the truck with wrench?
Dude this truck was bone stock when I picked it up from the origional owner who was the tender young age of 78. Been having a wrench-a-thon today tightening every bolt and nut that I could find. Even the gas tank hanger bolts were loose. How the hell does this $h!t get loosened in normal course of events!?
And that down pipe is what I created with what I created with what I had left after this morning.
I can get any bolt or nut in existance, as long as I know the size. There's a fastner (bolt and nut shop) place right up the road that's never let me down yet. So it's M10 1.25 pitch?
yeah that sounds about right but hey i was driving and my o2 sencer fell off so i got a new one cause it broke the wire and then putting it in i broke a bolt lol so its not leaking or anything and it in with only one bolt lol
Ran the origional swampthing for years without an o2 sensor. Did great, was getting about 22mpg highway wth 4.88s and 33x12.5s. Never had any problem other than blowing the headgasket once. But I think that's from running that seafoam treatment through the vac hoses. I've never once had a good experience with that seafoam stuff. It'll run great for a couple hundred miles, then all sorts of problems creep up. Fubar'ed the +2mm marine hg on my 12v cummins with arp headstuds after 200miles post treatment, toasted two lawnmowers, friend's 350sbc had to have extensive top end work after his treatment, and my cousin had all sorts of valve tap on his 99 f250's v10 after doing it to his. Call me crazy, but there seems to be a pattern there.
Though on the swamthing, I will admit, the hg DID blow after doing a treatment, but I did also drive it into a lake within that time frame too
So much for theory, then. A person could read all day long about how Toyota EFI's work and then someone shows up to disprove it. I guess the ECU just adapts. Hell....I dunno.
You didn't have the EGR hooked up either, did you? Did you advance the timing or anything?
Yeah I definitely think the ecu compensated for lack of o2 sensor. I just thought it always ran rich because of the compensation. Though it coulda been I had no problems due to the fact that I'm pretty much at sea level.
But yeah I also got rid of all the emissions I could. Killed the cat, no muffler, took off the egr and made a block off plate, removed all ac componets, redneck-ized the intake, played with the timing till it purred like a kitty (dunno if it ended up being advaced or retarded though). Could have been a combination of things that made the swampthing run like a raped ape.
Dunno. Its anyone's guess.
The Swampthing ran rich? And, you still got 22mpg on the highway?
Hmmm...I gotta figure somethin' out. After my rebuild, I'm still only getting 17mpg. Before, I was getting 18-19. This is with mostly flat/mild hill highway, inner city driving (some fairly good hills), and hauling. Plus, I've been running 31" a/t's and stock gears, but that was even before the rebuild.
You see, my O2 light has been coming on for a long time and haven't figured out what the problem is, yet. Advancing the timing leaned it out a bit, so it doesn't come on as much, but damn....I want better mileage. I'd figured tighter tolerances (new rings, bearings, etc.), rebuilt injectors, and lighter oil would net me better than the previous 18-19mpg, but it hasn't done so.
I need a new auxiliary air valve....I know that. I have no EGR and hollowed the cat (keepin' the muffler, though....can't stand the noise
), and my coolant sensor, TPS, ECU, O2 sensor are all good. Blah! Just need a diesel and veggie oil...lol!
I will say, she runs rather well despite the mileage, though.
), and my coolant sensor, TPS, ECU, O2 sensor are all good. Blah! Just need a diesel and veggie oil...lol!I will say, she runs rather well despite the mileage, though.
Yours a manual? I myself have never owned an auto, so I dunno what their comparative mileage is. Gear the beast! I'm a firm believer that gears make the biggest difference...
Elevation probably has its factor too... Dunno what arkansas is.
Think Ozarks, Clint....Ozarks. That's where I live. Lots'o hills!
Mine is a 5spd. Wouldn't have it any other way. Unless, there was a 6spd. I could live with that!
Wish I could regear. My wife's '92 has 4.88's (3.0 a/t) I'd love to swap out and put some 5.29's in my stock 3rd's to put on hers. But, the money just ain't there. Probably never will be now that gasoline continues to rise. Oh well.....suck it up, eh?! Lol!
), I don't see anyone will get an EFI system to run well without an O2 sensor.
