Ect Button
Old Feb 5, 2008 | 07:04 AM
White Rob's Avatar
Ect Button
ok so if you have a auto we all have the little ect button and we all know it increases power by having it on. Now my runner has 33s on it and in order to keep up with traffic on the uphill freeway i have to turn this on. The question is what is the downside of having this on i heard it uses more gas but I really have not seen a huge change any advice would be nice oh and i plan to re gear that will make a huge diffrence but if anyone knows why i should not drive with it on let me know.
Old Feb 5, 2008 | 07:06 AM
Tacoclimber's Avatar
All it does is electronically change the shift points in the transmission.
You will see a drop in mileage only if you can't keep your foot out of it.
Mine's on all the time.
If you're still curious, do a search for "ECT button" and you'll have plenty to read. '
By the way, welcome to YT.
Old Feb 5, 2008 | 07:09 AM
gilby4runner's Avatar
I wouldnt say it gives more power. It changes the shifting pattern of the Auto trans. It will shift at higher RPMS. It will use more gas in the long run. Regearing is an option you can look at to gain more power at Hwy speeds.
04 Rocko Taco's Avatar
I came in here to explain and offer sage advice.... but it looks like your covered.
Old Feb 5, 2008 | 07:20 AM
White Rob's Avatar
hey thanks guys i was just wondering if it was going to hurt anything if i had it on all the time till i could re gear
Old Feb 5, 2008 | 07:31 AM
Nah, I've had mine on constantly for a year, no problems. Again, all it does is change the shift points. Instead of shifting sooner in the RPM range, it holds out for a little longer.
Old Feb 5, 2008 | 11:13 AM
CILO's Avatar
just to chime in, i noticed that it will downshift more easily then its in pwr than when its in normal. i'm so used to having it in pwr that if i put it in normal while on the highway i tend to press more on the gas pedal in order for it to downshift and speed up. so in essence, I burn more gas.
Old Feb 5, 2008 | 03:30 PM
White Rob's Avatar
cilo that is what i found as well that i push it less so i use less gas not so heavy on it
Old Feb 5, 2008 | 03:34 PM
86blue4runner's Avatar
so basically its like the tow-haul mode in a GM?
Old Feb 5, 2008 | 03:40 PM
Probably. Not having owned any GMs, I can't say for sure, but I would imagine it does the same thing. It just holds out the shift points to higher RPM's, which gets you a little further into the power band before shifting.
Old Feb 5, 2008 | 03:45 PM
Joe's Toy's Avatar
ECT button Welcome to Yotatech.
Old Feb 5, 2008 | 06:19 PM
ozziesironmanoffroad's Avatar
yes, exactly.
Old Feb 5, 2008 | 06:45 PM
phenob's Avatar
Extremely Cranked Transmission, or as my large deathmetal hessian friend calls it, the "More Power.. UunnnGH!!" button, which over the years deteriorated to "poppin' the hetfield".
*end useless data transmission
Old Feb 5, 2008 | 06:54 PM
James Dean's Avatar
I drive with mine on all the time. Just raises your shift points.
Longbed 90
Mar 11, 2019 12:38 PM
Longbed 90
Oct 19, 2015 11:05 AM
Boomer8404
Sep 20, 2015 06:15 PM
VT2LAB
Sep 10, 2015 09:36 AM
Highlander Giant
Sep 8, 2015 06:46 PM
