Old Mar 11, 2016, 03:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
Print Wikipost
Easy Fix for Spare Tire Winch - Carrier
Old Aug 11, 2009 | 09:54 PM
sundog kid's Avatar
Well, I havent seen alot of DIY's on how to fix the spare tire carrier / winch that always seem to go kaput, so I thought I would do a quick little run-through, with bad cell pix, on how I fixed mine...
First you need a big ol socket
Then some heavy washers that fit in the socket, with a few stack in first to get the right gap. (the lighter will come into play later, dont you worry)
Put in like so.....
Take 3 straws, make one super straw, stick your WD40 straw into that, and spray the daylightsout of the winch, then go grab your impact gun and extensions
Push the socket with washers onto the winch slot, connect the extensions you need, from behind the body, and start zapping the winch, forward and back, as a friend sprays the heck out of it.
Well, that was easier then spending $50 at a wrecker, or $100 brand new....
And the Felatio! Your Done! Grab above mentioned lighter to smoke your fav cigar/cigarette as you marvel at how frugal and cheap you can be!
After spraying some WD40 up into the winch, working it a few times, mine can now turn with one hand quite easily.
I will be putting a grease nipple on mine, to make sure I can always grease it, and insure this will never, EVER happen again.
This concludes Sundogs Slick n Cheap Fix for The Common Shmuck.
Old Aug 12, 2009 | 03:37 PM
Tragic Drive's Avatar
Damn, You made that look easy.
Good job.
Old Aug 12, 2009 | 03:48 PM
camo31_10.50's Avatar
LOL..i just spray mine with PB blaster every now and then???
Old Aug 12, 2009 | 04:01 PM
1989toy4wd's Avatar
Good Idea...I just cut mine out, I couldnt use it anyway (37incher wont fit under there ) It worked fine though!
Old Aug 12, 2009 | 04:09 PM
BigBluePile's Avatar
Your's is a cable??!! Man, mine was a chain, whatta PITA that was...
Old Aug 12, 2009 | 04:11 PM
ya mines a chain too???..lol...i guess one could take some steel cable and replace the chain with it???..or some synthetic rope?...like whats used for the winches?
Old Aug 12, 2009 | 04:12 PM
I took mine off and now have head room to work on the rearend.
Old Aug 12, 2009 | 04:13 PM
Robert m's Avatar
the 2wds came with a cable. looks like someone switched it out before.
Old Aug 12, 2009 | 04:18 PM
My 95 4x4 has the cable as well from the factory. I'm going to use this method to exercise it. I like the socket washer idea.
Old Aug 12, 2009 | 04:20 PM
gah you guys suck
although mine is really easy to deal with..lol
Old Aug 12, 2009 | 04:44 PM
slacker's Avatar
moldy oldy repair .... good to bring it back to life though
Old Aug 13, 2009 | 06:26 AM
sundog kid's Avatar
I couldnt find any other posts on how to free this up, but I was sure someone else had done this, its the most logical way to break it free.
Ill be posting pictures of my uber cool grease nipple extension to the winch
Old Aug 13, 2009 | 07:03 AM
BoostinChick's Avatar
My fix:
Old Aug 13, 2009 | 07:10 AM
crafthorse's Avatar
I dont have a spare tire carrier...oh wait yes I do, its the bed of the truck under the tool box!
Old Aug 13, 2009 | 07:27 AM
874runnersr5's Avatar
haha my fix
Old Aug 13, 2009 | 08:18 AM
PCE91V64x4's Avatar
I took mine off and put in its place a spare wheel carrier from a current generation tundra. Works great.
Jun 1, 2021 01:51 PM
DrZero
18
Jul 24, 2015 11:31 PM
sabine
Jul 18, 2015 03:59 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
