Easy Fix for Spare Tire Winch - Carrier
6 Attachment(s)
Well, I havent seen alot of DIY's on how to fix the spare tire carrier / winch that always seem to go kaput, so I thought I would do a quick little run-through, with bad cell pix, on how I fixed mine...
First you need a big ol socket http://i6.photobucket.com/albums/y24...P/IMG00474.jpg Then some heavy washers that fit in the socket, with a few stack in first to get the right gap. (the lighter will come into play later, dont you worry) Attachment 184403 Put in like so..... Attachment 184404 Take 3 straws, make one super straw, stick your WD40 straw into that, and spray the daylightsout of the winch, then go grab your impact gun and extensions Attachment 184405 Push the socket with washers onto the winch slot, connect the extensions you need, from behind the body, and start zapping the winch, forward and back, as a friend sprays the heck out of it. Attachment 184406 Well, that was easier then spending $50 at a wrecker, or $100 brand new.... Attachment 184407 And the Felatio! Your Done! Grab above mentioned lighter to smoke your fav cigar/cigarette as you marvel at how frugal and cheap you can be! Attachment 184408 After spraying some WD40 up into the winch, working it a few times, mine can now turn with one hand quite easily. I will be putting a grease nipple on mine, to make sure I can always grease it, and insure this will never, EVER happen again. This concludes Sundogs Slick n Cheap Fix for The Common Shmuck.:rockon: |
Damn, You made that look easy.
Good job. |
LOL..i just spray mine with PB blaster every now and then???
Good Idea...I just cut mine out, I couldnt use it anyway (37incher wont fit under there :hillbill: ) It worked fine though!
Your's is a cable??!! Man, mine was a chain, whatta PITA that was...
ya mines a chain too???..lol...i guess one could take some steel cable and replace the chain with it???..or some synthetic rope?...like whats used for the winches?
I took mine off and now have head room to work on the rearend. :D
the 2wds came with a cable. looks like someone switched it out before.
My 95 4x4 has the cable as well from the factory. I'm going to use this method to exercise it. I like the socket washer idea.
gah you guys suck:roll:
although mine is really easy to deal with..lol |
moldy oldy repair .... good to bring it back to life though
I couldnt find any other posts on how to free this up, but I was sure someone else had done this, its the most logical way to break it free.
Ill be posting pictures of my uber cool grease nipple extension to the winch ;) |
I dont have a spare tire carrier...oh wait yes I do, its the bed of the truck under the tool box!
I took mine off and put in its place a spare wheel carrier from a current generation tundra. Works great.
