E-Brake doesnt work sometimes
ever since i got my truck back in may of this year, my ebrake has been really weak. i can park it on a small hill and it will slowly roll backwards. (i know you are supposed to park it in gear, but i was just checking it) i stopped in my school parking lot yesterday and went to pull the ebrake handle back and there was no pressure on it and when it got about halfway it started to move further out by itself. I decided to leave it like that and when i came back out later it had a little bit of pressure(same as it usually did). it worked fine the rest of the day, but it did it again this morning. i havent had a chance to look at it yet, but where should i start? i figure that ill go ahead and tighten it also, so it will hold better. Any ideas what this could be?
My bet is on rear shoes either just being worn and/or the little toothed adjuster in at least one of the drums has seized up and so the rear shoes aren't adjusting as the shoes wear down.
That's what happened to mine. Off road driving can get water in the drums and that can make all those little parts rust and corrode. Major flaw in drum brake design.
bell cranks.
make sure the bell cranks are fully functioning. known for "freezing" up due to corrosion. can be "manipulated" (beat upon until moving freely) to get them to work again (in the best case scenario) new brakes or servicing the brakes won't matter if pulling the e-brake won't move the parts to engage the brakes.
likewise you could have a cable issue. start from the back, work towards the front.
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
