Dual Batteries
Old Apr 5, 2009 | 09:08 PM
Plumbrbob's Avatar
Originally Posted by StangBanger
Im about to get a winch mounted and this a great idea. I dont know much about batterys and battery set ups but shouldnt your alternator keep things rolling? Or is this dual battery setup to put less strain on your alternator?
When your heavy winching like in a recovery or a self recovery for long periods of time (for me it was about 45min or more) your battery can get low on juice even with the alternator charging it.
Imagine what your battery is like after you jumped it when you found it dead in the morning.
I know its the battery that was low on amperage because I linked the winch up to my primary battery and it started to pull again like a champ.
Old Apr 5, 2009 | 09:14 PM
StangBanger's Avatar
So you have your duals set up so you can connect your winch to whichever batt you want? Or you just flip a switch that take it from one or another?
Old Apr 5, 2009 | 09:15 PM
RMA's Avatar
RMA
Originally Posted by scuba
Everything looks good, But right here it looks like your upper radiator hose is about to come off....
Looks like it but its not , Thats the way the tube comes out of the radiator it comes straight out about an 1 1/4" then turns left for about 3/4 " thats a toyota radiator. THanks Tho!!
Old Apr 5, 2009 | 09:17 PM
RMA's Avatar
RMA
Also if you look close you will see it has to if not the hose will hit the fan.
Old Apr 5, 2009 | 09:19 PM
  #25
RMA's Avatar
RMA
Hey , do you have a fuse inline with your winch, I need to add one but am unsure of the size to put in.
Old Apr 5, 2009 | 10:01 PM
  #26
Plumbrbob's Avatar
Yes i have installed a switch that links the two batteries together bypassing the isolator. I installed it to self jump myself in emergencies but used it in my last vehical recovery effort.
my mile maker pe8000 did not come with or call out a inline fuse? or did it?
Old Apr 6, 2009 | 03:50 AM
  #27
GSGALLANT's Avatar
I don't believe people generally fuse their winches. I didn't. Warn doesn't recommend to in their users/installation manual.
Just make sure to protect the cables by routing them in safe locations and covering them up with split loom as required.
Old Apr 6, 2009 | 07:22 AM
  #28
scuba's Avatar
Never had a 3.0 so I wouldnt know, Just lookin out !!
Wouldnt mind the dual batteries, Congrats !!
Old Apr 6, 2009 | 04:20 PM
  #29
RMA's Avatar
RMA
THats a good idea , I am going to add a swith also.
I routed it the best I could but if I were to crash or something I dont want any fires or explosions.
Old Apr 6, 2009 | 04:21 PM
  #30
RMA's Avatar
RMA
THanks anyway.Hows that cart coming along finished yet?
Old Nov 10, 2012 | 12:47 AM
  #31
Loz 23's Avatar
Did anyone ever follow through and add a snorkel AND dual batteries. Am considering the best way to do both at the moment.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
