Drop braket
Old Sep 6, 2006 | 06:28 PM
94toyota4x4's Avatar
Drop braket
Anyone know where I can buy a an adjustable drop braket for the rear brakets?
Old Sep 6, 2006 | 06:38 PM
Elton's Avatar
what ?
Old Sep 6, 2006 | 06:45 PM
wjwerdna's Avatar
honestly... elaborate on what you are looking for... what is this for? a 94 4x4 maybe given your name... help US help YOU, lol
if your are looking for an adjustable braCket to remount rear exhaust braCket, they can be found at most auto parts stores
Old Sep 6, 2006 | 06:48 PM
Marc P's Avatar
huh??????????????
Old Sep 6, 2006 | 06:53 PM
snap-on's Avatar
bumper brackets?
LSPV?
Old Sep 6, 2006 | 07:00 PM
sorry guys, for the rear brakes where that valvue decides how much brake fluid is sent to the rear brakes, it all depends on how much the rear springs are compressed, its on a 94 toyota pickup.
Old Sep 6, 2006 | 07:14 PM
86SR522REEFI's Avatar
In english this time
Old Sep 6, 2006 | 07:36 PM
Chainlink's Avatar
rod to proportioning valve?....why do you need a new one? wondering because everyone I have seen is bent but worked none the less.
Old Sep 6, 2006 | 08:09 PM
oo really, I was told if you get an adjustable drop braketyou can push a lot more brakeing power out of the rear brakes, heres a link
http://toyota.off-road.com/toyota/ar....jsp?id=186210
Old Sep 6, 2006 | 08:13 PM
Marc P's Avatar
This bracket usual comes with the Downey kit, but I am sure you could make it super easy...
https://www.yotatech.com/forums/show...highlight=lpsv
Old Sep 6, 2006 | 08:53 PM
slosurfer's Avatar
I agree, make one yourself. Use a peice of aluminum flat stock.
Marc, in that pic above do you have a drop bracket on your panhard? It looks like it has a lot of rake to it?
edit: I just noticed that that wasn't yours Marc!:pat:
Old Sep 6, 2006 | 08:59 PM
Marc P's Avatar
Not my truck....Mine looks like this...
I just didnt have a pic of my LPSV bracket on mine
Old Sep 9, 2006 | 12:09 PM
BeaterToyota's Avatar
[QUOTE=Marc P;984048] I am sure you could make it super easy...[quote]
Yep. Just cut a length of metal to the length you want and drill the necessary holes.
I used a .25"x1.25" piece of steel. I cut it long enough to raise the end of the LSPV rod 4" (the height of my suspension lift). Then I just drilled two holes in each end and bolted it in place.
Old Sep 9, 2006 | 12:43 PM
4x4Lamm's Avatar
NWOR and 4Crawler sells em.
Lamm
RDubya
Feb 10, 2017 04:46 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
shredder4286
Oct 1, 2015 01:09 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
