differential extension ???
Old Dec 31, 2008 | 07:01 PM
rangerruck's Avatar
I saw a thread in the search site, about extending the breather on the rear diff.
Then, I forgot where I saw it. So I started searching again, and eventually found it, with the nice pics. However, there was one thread of a dude, who did an extension on both his front and rear diff.
Okay, sounds good i thought, and then another dude chimed in, and said if your 4rnr has independent suspensions, not solid axles, then you do not need to do the front diff. What say the experts, should I do the front, or not? I have 4x4, with auto locking hubs on the move, and I suppose indy suspension both front and back.
Old Dec 31, 2008 | 07:13 PM
toyota4x4907's Avatar
What year is your 4runner? '84 and '85 have solid front axles. '86+ have independent front and a 'solid' rear axle. I'm pretty sure you still need to extend the front diff.....
Old Dec 31, 2008 | 07:26 PM
BigBluePile's Avatar
yup still have to do the front
Old Dec 31, 2008 | 10:52 PM
rangerruck's Avatar
it is an '88, with 4x4 on the fly, and a 22re engine... 5 speed standard tranny.
Old Jan 1, 2009 | 04:12 AM
redvette's Avatar
Still need to do it.
Old Jan 1, 2009 | 04:31 AM
91 4Runner's Avatar
Regardless of Solid or IFS you still have to extend it if you run mud or water. On yours it still has the same 1 way valve on the front and rear. So it's always a good idea to extend them.
Old Jan 1, 2009 | 06:22 AM
mistreatedtoys's Avatar
There used to be a post somewhere about using a nissan diff breather with the part number and everything. This was just a barbed fitting with metric threads that just replaced the factory little breather. That and a piece of 1/4 inch fuel line you could run it up and put a breather on it.
Old Jan 1, 2009 | 07:01 AM
Ron Helmuth's Avatar
here is the J.A. link
here is the link guys. Excellent instructions with part numbers. not sure of fitment to your diffs, but this is the writeup I used for my 3rd gen.
http://www.top4runners.com/ja/diff.html
Old Jan 1, 2009 | 07:55 AM
or here, scroll to the bottom of the page:
http://www.downeyoff-road.com/Chassi...riveTrain.html
or:
http://www.4x4wire.com/toyota/minutemods/breather/
Old Jan 1, 2009 | 08:53 AM
jsn_stockard's Avatar
Do both, you never know when you might get in a bit too deep. Make sure you don't kink the breather hoses either, that will make your diffs suck in water if they are hot.
Old Jan 1, 2009 | 09:50 AM
86tuning's Avatar
if you want the part that screws into the housing, you can just use a 1/8" NPT fitting with a hose barb on it. $3-5 from a hardware store. The same store you'd get the tubing from anyways. If you run clear tygon style tubing you can SEE if muck gets inside the tube.
Old Jan 1, 2009 | 09:59 AM
abecedarian's Avatar
Originally Posted by 86tuning
... If you run clear tygon style tubing you can SEE if muck gets inside the tube.
Not to mention tygon is fuel and oil resistant unlike regular clear vinyl hose.
Old Jan 1, 2009 | 11:22 AM
space-junk's Avatar
is there a way to pop off the cap that looks like a calve stem cover and just mount some hose to that?? i mean, if i can get away with not replacing anything that would be sweet...
Old Jan 1, 2009 | 03:09 PM
Matt16's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=186211
Go to a Nissan dealership and ask for part # 38323-C6010. Its a nipple that threads into the axle and you clamp some fuel line onto it. The same part works for front and back.
Yes you do need to a front breather, not sure what the guy saying you didn't was thinking. Its pretty obvious where it is if you take off the skid plate and look at the front of thediff.
Old Jan 1, 2009 | 03:17 PM
89silverpu's Avatar
Just use a little ingenuity
https://www.yotatech.com/forums/f116...ension-139986/
Old Jan 1, 2009 | 03:26 PM
rangerruck's Avatar
did it today, on both front and rear, with part number 90404-51026. This is the part number from Toyota, and it is called a Union. It cost 5.75. I used rubber , black, fuel line hose, 1/4 " dia, from a auto parts store; i thought it would be the toughest and least likely to kink. The back was easy to get to, but I couldn't figure out where I wanted to run it to. So I wanted to try to run it to the gas tank neck, but I will need to drill out a hole for it, which has got me a little freaked out.
Old Jan 1, 2009 | 09:11 PM
rangerruck's Avatar
I think maybe I'll run both up front , under the hood, before the air intake, right by the front fender, plus i will use color coordinated tie wraps, so i don't forget which tube goes where...
Old Jan 2, 2009 | 02:34 AM
91 4Runner's Avatar
I ran my rear into the rear driver side cargo box and then up my 1st gen rollbar, and the front I ran up behind the wiper motor.
Old Jan 2, 2009 | 06:07 AM
rangerruck's Avatar
Really!!! How did you get it into your cargo box, did you have to drill a hole, did you remove the cargo box first? give me the details, as I would rather do it myself, than be charged by my Mechanic.
mine is an 88' so it should be a similar setup to yours.
Old Jan 2, 2009 | 08:20 PM
rangerruck's Avatar
also , can you take apart the outer gas feed stuff, inside the gas door, without having to go underneath to take stuff apart?
