differential extension ???
Old Jan 3, 2009 | 02:17 AM
91 4Runner's Avatar
I had some body rot, so it was easy for me to drill a hole into the cargo box and then into the cabin (sealed the box with RTV). Then I fixed the body.
Old Jan 3, 2009 | 05:14 AM
waskillywabbit's Avatar
Biggest thing is you don't want any "U" sags in the vent line where fluid might become blocked and thus clog off the vent...seal go boom. You need some slack just don't let the line sag to make any "U"s.
Old Jan 3, 2009 | 08:21 AM
iamsuperbleeder's Avatar
I am by no means questioning your experience, but a little fluid will stop the air-flow, really?
I would think the air would push it a little bit, then the air would just "burp" past the trapped fluid
Old Jan 3, 2009 | 08:29 AM
4Crawler's Avatar
BTDT replaced an axle seal because of it. Think 90W gear oil and think about how thick that stuff gets in cold weather and put that thick oil in a small tube and you can't even blow through it (and I did try this and that is how I found the source of the problem). And the problem is while the gear oil in the axle heats up with use, the oil trapped in the vent line has no source of heat and once that axle heats up, pressure builds up and it'll find the easiest way out (ideally the vent line unless it is clogged).
I run the 1/8" NPT fittings on mine, works fine and they cost about $1 ea.
  #25
Ron Helmuth's Avatar
iamsuperbleeder-
good thought but the pressure out of the diff is very low-like 1-4 psi and may not be enough to "burp" past the gooey fluid....
yah-what 4crawler said....
Last edited by Ron Helmuth; Jan 3, 2009 at 08:29 AM. Reason: roger knows his stuff
Old Mar 18, 2011 | 05:42 PM
  #26
WHAHAHAJR's Avatar
Trying to resurrect this old thread. Does any one know the thread pitch and size of the nipple needed?
92 22re IFS
Old Mar 18, 2011 | 06:11 PM
  #27
4Crawler's Avatar
Some size info below:
- http://www.4crawler.com/4x4/CheapTri...html#Breathers
justdifferentials
14
Jun 11, 2017 08:36 PM
shooter86314
Jan 7, 2016 07:05 AM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
matthew138
Sep 3, 2015 08:21 AM
