Diesel conversion underway
Old Feb 9, 2006 | 05:09 PM
  #81
suprathepeg's Avatar
That 6.2 was a piece of junk. The dynamics of diesel design are totally different from gas.
Old Feb 26, 2006 | 07:45 PM
  #82
Well, I got herup and running... All I can say is that this engine is amazing! Lots of torque and power throughout the rev range. I'll post a video in a few days..
Old Feb 26, 2006 | 10:45 PM
  #83
dirtykaw's Avatar
Curious if you've had much luck with jarco halfcuts..for instance, was everything packed well? Clean?
I seem to remember hearing good and bad about them but I could be mistaken..
If you happen to do an accurate measurement of fuel economy when you finish that would be interesting to hear about
Old Feb 27, 2006 | 06:13 AM
  #84
I cant say enough good about Jarco. The ut was well shipped and represented VERY accurately...I highly recommend them. I'll post mileage figures when I get them in.
Old Feb 27, 2006 | 07:20 AM
  #85
Blizzard's Avatar
Hey Dieselyota, glad to hear you completed your swap.
It's strange in Japan and the UK the most average KZN-130's are automatics, and here in Spain all the 4Runners (Diesel or gas) were manuals, I think there's no automatic 3.0TD LHD 4Runner...
You need one of those now:
David
Old Feb 27, 2006 | 07:16 PM
  #86
Hey blizzard, what's the availability of LHD wiring harnesses over there for these vehicles?
Old Mar 1, 2006 | 06:34 AM
  #87
Blizzard's Avatar
I suppose there's no problem to get them in the stealer, but the cost will be expensive (At least uses to be).
In yards bad... They use to cut the wires...
But remember here we've KZN-130's with 1KZ-T engines, not 1KZ-TE.
David
Old Mar 1, 2006 | 07:20 AM
  #88
See what you can find on the lines of a wiring harness for a lhd engine wiring harness for a 2lte or ln130 body style.
Old Mar 2, 2006 | 10:06 AM
  #89
jjenks0's Avatar
Is the 3rz a diesel?
Old Mar 2, 2006 | 09:45 PM
  #90
irott's Avatar
So how is this coming along?
I want to see video.
Old Dec 20, 2006 | 07:47 PM
  #91
photomike72's Avatar
Any new info???
Old Dec 20, 2006 | 09:10 PM
  #92
Bumpin' Yota's Avatar
Originally Posted by trythis
they tried to do that desiel conversion in 6.2 gas engines in suburbans too, I think. They had the same problem, I wounder if a 22re could handle a deisel conversion, just in terms of heat and stress
eeeh no. The 6.2 is the same block as the 6.5 which was a dedicated, from the ground up diesel. You are thinking of the 5.7 diesel, which GM attempted to convert. The 6.2 was FAR better and more reliable an engine albeit underpowered. The 6.5 was basically the same block punched out more, turbo charged and went to an electronic standyne IP in 94. The 3 big problems with todays 6.5 is the 21.3:1 CR (way too high for more boost than 15psi), indirect injection, and low nickel content block (main webs like to crack).... Even still the last variant of the 6.5 before the introduction of the 6.6 duramaxx pushed the block to its limits with hp eclipsing 230hp and tq over 450tq...
Compared to today's diesels yes. For that matter the 6.5L I drive around and the 7.3 navistar I444 (old powerstroke) is too. But the 6.2 was infinately better than that damn 5.7.
Old Dec 20, 2006 | 09:16 PM
  #93
Have yall swapped anything else diesel into 2nd gen yota's? ISBs? 4bts? 6.5LTDs?
Old Dec 22, 2006 | 09:58 AM
  #94
4runner4ever's Avatar
In one of the first posts you mentioned using biodiesel.
If it's a 1KZ-TE you will have to have the injection pump rebuild with Viton O-rings (I think it was Viton).
We have a lot of those engines here, 1KZ-T and 1KZ-TE types, and the high pressure common rail injection pumps fail over time (read: short period, like months) when used with biodiesel.
I'm not making this up, this is based on experience over several years. Like 98% of the toyota van's, busses and 4X4's are diesel here in the Netherlands.
That makes my gasser quit rare here.
Old Apr 3, 2007 | 12:54 PM
  #95
jungle_runner's Avatar
Originally Posted by stumpbum21
i had planned to move the exhaust outside the frame on the driver's side to make room for the 2nd tank, but with this swap all of the dimendions and routing will change. besides, everything is on hold 'til i get the cash for the diesel swap
downey-toyota sells 14gal auxzillary tanks that mount nicely under the farme:
http://downeyoff-road.com/BodyComponents/index.htm
i will absolutely go diesel soon and get an extra tank ... i am yet to decide on an egnine ... i have an '88 22re ... thinking about a 1kz-te or a 6cyl 1hz ... but i am leaning more toward a 4cyl for economy and ease of the swap
Old Apr 3, 2007 | 01:27 PM
  #96
Robrt32's Avatar
I really wish i could a deisel anything considering i could get free fuel.. That would be nice. My boss would let me fill out of his tank at no charge i'm sure.
Old Apr 3, 2007 | 01:37 PM
  #97
Fergie's Avatar
www.dieseltoyz.com
'Nuff said.
Old Jan 26, 2009 | 08:12 AM
  #98
1TallTXn's Avatar
dieselyota, curious what kind of mileage you're getting out of that 1kz and how you're liking it overall.
I've got an '88 22re 4Runner that I'm dreaming of stuffing a diesel in. Any idea how hard this is compared to the newer models? Would prefer the power of the 1kz vs the 2L, but I'm open to suggestions.
I do auto repair for a living and put a Cummins 6BT in a FJ60, so I should be able to handle the work.
Old Jan 26, 2009 | 09:44 AM
  #99
93toyrunner's Avatar
Ihave always wanted to do this swap so bad, I wish i lived in texas i would be at your shop before you knew it. I have an auto matic in mine right now the A340H is that what the trucks have that you are doing them in. if so do sell just the wiring kits if i did the swap myself then wanted you harness.
Old Jun 24, 2010 | 02:55 PM
  #100
Mountain Cop's Avatar
Bump (of an old thread).... just cuz its so cool.
