Diesel conversion underway
Old Jan 29, 2006 | 07:15 PM
You can reach me at:
solohant@yahoo.com
phone number is: 210-683-9663
For the time being, we are performing the swap at a shop in Austin. If you have any questions, ask away. Yes, the unit is from Jarco. The one we have right now has 72,000 miles on it. I just purchased a timing belt/tensioner/water pump/idler pulley and factory coolant from Toyota for less than $300 complete. I always recommend doing this simple maintenance while you can easily get to it. You never know with these japanese half cuts. The mileage may be low but they idle alot in traffic. This makes for cheap insurance. -Todd
Old Jan 29, 2006 | 07:44 PM
stumpbum21's Avatar
what about fuel tanks and the lo press pump and lines? do you supply and install them or do i have to source a donor?
Old Jan 29, 2006 | 07:57 PM
The half cut comes with a diesel filler tube. You just take out the in-tank fuel pump. Crimp the wires powering the pump (outside the tank), then replace the missing pump with a length of rubber fuel injection hose, then cap off the breather tube going out of the tank. There is no low pressure pump or lift pump. The fuel pressure it maintained by the injection pump. -Todd
Old Jan 29, 2006 | 08:03 PM
stumpbum21's Avatar
i'm planning on dual tanks, any worries or advice?
Old Jan 29, 2006 | 08:29 PM
  #25
Where will you mount the second tank? Gas or diesel?
Old Jan 29, 2006 | 08:44 PM
  #26
stumpbum21's Avatar
diesel. mounted on the driver's side opposite the stock tank. i took measurements and a 29"x14"x14" outside measured tank will clear the driveshaft, cab and rear crossmember. it will also be level with the bottom of the frame. i think. i may need the make room for the filler neck. haven't got that far, yet.
Old Jan 29, 2006 | 08:59 PM
  #27
The best one's I've seen are mounted in the bed inside of a tool box. That way you can easily remove them if necessary. Usually for WVO conversions.Will that clear the exhaust system? -Todd
Old Jan 30, 2006 | 09:26 AM
  #28
stumpbum21's Avatar
i had planned to move the exhaust outside the frame on the driver's side to make room for the 2nd tank, but with this swap all of the dimendions and routing will change. besides, everything is on hold 'til i get the cash for the diesel swap
Old Jan 30, 2006 | 09:39 AM
  #29
stumpbum21's Avatar
does the stock axle gearing work with the diesel?
Old Jan 30, 2006 | 02:19 PM
  #30
Sure does.The half cut comes with a complete front diff. I could add the rear if I really wanted to. -Todd
Old Jan 30, 2006 | 02:42 PM
  #31
Praufet's Avatar
is the diesel front diff different? or just something you can ebay to help recoup some of the cost
Old Jan 30, 2006 | 03:12 PM
  #32
suprathepeg's Avatar
You put it on the front of your truck
Old Jan 30, 2006 | 06:36 PM
  #33
irott's Avatar
With a $4999 price tag, I would sell as much of the leftovers as I could.
Jarco only gets a Manual KZ-TE in about once a year so I guess I should start saving my pennies for next year.
Old Jan 30, 2006 | 08:51 PM
  #34
I wouldnt put a manual one in if it were me. The manual trans are punchy, but nothing like the auto box models. The autos keeps the turbo spooled up throughout the gears so it's seems much more peppy than the manual.Plus, the manual trans models are rare as hens teeth. It's not so much that they're rare in Japan, just here. In Japan, people tend to hang onto them alot longer so they are higher mileage half cuts.
Old Jan 30, 2006 | 09:34 PM
  #35
irott's Avatar
It is a Torque monster. ^_^
Old Jan 30, 2006 | 11:02 PM
  #36
radrav4's Avatar
another to the list
i'm looking at swapping my 3.slow in the near future its nice to see all the
TOYOTA choices diesels and gas, I'm leaning toward the diesels after driving one overseas smooth, with plenty of torque. was a toyota FX i believe..I'll be watching out for your threads for sure.
Old Jan 31, 2006 | 04:33 AM
  #37
Praufet's Avatar
how much work would it be to go from manual->auto?
Old Jan 31, 2006 | 06:18 AM
  #38
You are essentially swapping the entire drivetrain anyways including the wiring. Manual to auto would not be more difficult.
Old Jan 31, 2006 | 08:47 AM
  #39
gwhayduke's Avatar
The ECU probably is transmission specific. I'll check the wiring diagram I have on a 1kz-te and repost.
Old Jan 31, 2006 | 09:06 AM
  #40
If your gonna do a 5spd with a 5spd ecu it should be no problem at all, at least it isn't with a 3.4 swap. Even still there are those who have used an auto ecu and fooled it to make it work with a 5spd.
