dies
Old Jan 26, 2009 | 06:10 PM
87runnerAK's Avatar
dies
i have an 87 4 runner that runs decent but every now and then while driving it spudders and the check engine light comes on. sometimes while sitting at red lights or even sometimes when i start it, it doesnt want to stay running and takes a while to get going...kinda seems like a fuel problem but im not 2 positive..any inputs would be appriciated, thanks.
Old Jan 26, 2009 | 09:06 PM
Moebass's Avatar
you may want to look for vacuum leaks, idle air control may be dirty, your mass air flow meter may be having an issue. i know mine did, the truck would barely move sometimes. the only way to really test your fuel pump is to mount a gauge to monitor fuel pressure while your engine runs. also check the voltage of your battery. engines run bad when the voltage gets real low, 10.5 volts & under is bad. 13.5 when running is normal.these are just general suggestions because viewing your post does not tell us mileage, engine, last tune-up. just try simple things to see if that helps the problem. look at your air filter and work your way to the motor. maybe also a clogged cat. convertor. the motor has a hard time hoffing out the exhaust at low rpms and it runs better with more pressure and heat. a glowing cat after driving ten miles is a great indicator. hope this helps. any more details would help.
Old Jan 26, 2009 | 09:11 PM
toyota4x4907's Avatar
well you're saying you're getting a CEL light.....have you checked so see what the stored code is? That would be helpful to both you and us Go check the code(s)!!!!!!!!
Steven.m.paulk
Jun 7, 2020 10:45 AM
shisha1999
Mar 3, 2016 07:09 PM
Chicken12
Oct 14, 2015 03:54 PM
Rcbc92
Sep 26, 2015 03:00 PM
