did isr pipe mod...runner stalling.
Old Nov 11, 2006 | 08:53 PM
Elton's Avatar
fuse box under the hood says efi fuse
91_4x4runner's Avatar
In the main fuse box by teh battery; it should be labled EFI ;-)
Old Nov 12, 2006 | 05:56 AM
traben27's Avatar
that didnt make me feel like an idiot haha thanks.
edit: yeah that didnt work. i'm pretty sure it has to do with a seal because it starts fine and then shakes a little while its dying. i put silicone all over the seal last night, but it didnt work so i'm back where i started.
Old Nov 12, 2006 | 07:02 AM
suprathepeg's Avatar
IF there is any air leakage in there it will cause the problems you are having I know cause I've had the same problem.
Old Nov 12, 2006 | 08:30 AM
  #25
traben27's Avatar
i went back and tightened EVERYTHING super super tight and then it ran almost perfect...it was idling at around 1000 (yes thats high) and then it slowly dropped until it was revving itself to keep going at 400 rpms. now when i turn it on (the engines heated up now)...the only thing it does is stutter at that low range. what happened?
Old Nov 12, 2006 | 09:56 AM
  #26
Godzilla's Avatar
all i can say is take everything off, put back all the stock components and fire it up...if it runs redo the isr mod, but at least you will know its not anything else, and you may catch your mistake
Old Nov 13, 2006 | 02:12 PM
  #27
traben27's Avatar
good news! i found and fixed the problem!
i decided to finally be smart and follow godzilla's advice. so as i was taking the pipe off, i found a tear in the rubber seal at the throttle body end of the pipe. No wonder it wasn't working, this hole was about an inch long. I also realized i had overlooked it because it was partly under the hose clamp thing (i'm blankin on the name at the moment). I went and got a new one, fired it up, and bam! worked like a charm.
thanks for everyone's help
Old Nov 13, 2006 | 02:15 PM
  #28
Elton's Avatar
good to hear .... hows the power any seat of the pants gain
Old Nov 13, 2006 | 06:02 PM
  #29
traben27's Avatar
i wouldnt say that haha. but i can definitely feel a change in throttle response. it doesnt seem to struggle to get up there as much..well atleast for the 3.0
Old Nov 13, 2006 | 06:14 PM
  #30
jarrod7219's Avatar
another option for others in this situation would be to spray some carb clean around the suspect area to find the leak. The engine will race when you find the leak.
Old Nov 21, 2006 | 09:03 AM
  #31
Tigerstripe40's Avatar
Quick question for you
Is the bend of the pipe you used to do your ISR a 45 degree bend in one plane?
When I did my mock up ther ewas about a 45 degree bend then a 15 degree bend in another plane.
Did you use 3" pipe or 2.75" pipe?
Thanks!
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
larrys93pickup
Sep 17, 2015 07:05 PM
Boomer8404
Sep 10, 2015 09:01 AM
