Old Feb 9, 2016, 10:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guide
Print Wikipost
Dash & Tail lights DON't WORK
Old Feb 28, 2009 | 03:11 PM
LIBANKER's Avatar
1990 4WD Toyota Pickup DLX.
The tailights do not work and the dashborad lights are out. The directionals, brake and reverse lights work fine. There is power to the taillights and the dash. The 15 amp fuse do NOT blow.
I replaced the taillight relay, rheostat,ON/OFF switch on the sterring column. I;ve tested every fuse and they are fine.
All Fueses are tested and good.
checked liscense plate lights for moisture.
cleaned all contacts in both tailight assemblies.
replaced all tailight bulbs and dash bulbs.
I traced all wires in the engine compartment and they are fine. I traced harness under truck back to the ECM and they are fine and cannot find any cuts or breaks,
currently, have the entire dash in pieces and no shorts.
Am I missing anything. Does anyone have any ideas on what I can do.
Please Help....
Lenny
Old Mar 1, 2009 | 09:12 AM
arizonaguy's Avatar
no lights
id seriously beg to differ that you do have a bad fuse
Old Mar 1, 2009 | 09:16 AM
bipolarandproud's Avatar
I'm have the same problem ,I think my problem is the relay .
Old Mar 1, 2009 | 10:19 AM
LIBANKER's Avatar
NO Bad Fuses
I have a fuse tester that lights up when it gets continuity. I have tested every fuse under the hood as well as in the fuse box. Besides I am getting power to the dash and lights but they do not work.
Old Mar 1, 2009 | 10:27 AM
91Toyota's Avatar
I had no tail lights and no dash lights because my tail light fuse was burnt out. The fuse box was by my left foot while driving under the kick panel. Good luck!
Old Feb 21, 2012 | 05:52 PM
Zgs's Avatar
Zgs
Please Help....
Lenny
Hello Libanker.
I have the same problem as you, No dash or runing lights.
I cant find the problem either.
What did you find out about yours?
Any help would be appreciated. Thank you.
Zgs.
Old Feb 21, 2012 | 06:03 PM
Zgs's Avatar
Zgs
Was that it?
Is the relay locted on the fuze box next to your left foot?
I'm about to replace it just to rule it out.
Is their a way to test the Relay?
Thanks. Zgs
Old Feb 21, 2012 | 10:56 PM
wyoming9's Avatar
Red face
Do you have a loose connection in the fuse block??
Do you happen to have one of those trailer light converter boxes that cause nothing but trouble.
You say you have voltage to the lights??
If that is indeed true you have lost your ground for that circuit.
Try making a new ground coming off the tail light socket.
You can check if the coil is open in the relay.
But unless you pull the cover off you have no idea what the contacts are like could be so burnt they no longer work.
Old Feb 22, 2012 | 02:05 PM
Zgs's Avatar
Zgs
I'm looking for the lose connextion on the fuse box, No coverter box.
no voltage at light.
What I need to do is check the relay.... I'm just going to replace it and hope for the best.
I just have to figure out where it's located, I think it's the relay attached next to the fuse block next to me left foot.
I have a 1990 toyta pick up 4 wheel drive v-6 but i don't know what model it is.
Old Feb 22, 2012 | 02:32 PM
shakes_24's Avatar
had the same problem on the same truck. It was the trailer light wiring shorting out... fixed it dropped in a new fuse and it was good to go
Old Feb 22, 2012 | 02:36 PM
Zgs's Avatar
Zgs
I found out I have a 1992 Hilux and the relay is called the... Tail light relay.
now what I need to know is where it's located?
My fuse is good and I have no short with the trailor lights.
Old Feb 22, 2012 | 04:06 PM
Zgs's Avatar
Zgs
All good. I found the tail light relay and it is the problem. (on fuse box next to left foot)
Bye past the relay and the lights work.
I have a relay on order and soon I will be back on the road.
Thank You for your help.
Old Dec 15, 2012 | 04:18 PM
vinman3's Avatar
Same Problem - Fixed it
Hey Guys,
I have a 1986 pickup sr5 xtra cab 4x4 with the same issue, I checked everything on mine as well. I had no blown fuses all grounds were good. When I turned the stalk I can hear the relay click but still no lights. I decided to talk the relay apart.
It was terribly corroded inside, I tried cleaning it but it was too far gone and I didnt have the right tools.
I ordered on online for 8 bucks and it fixed the issue.
HTH
Vinny in PA
240K miles and now with dash lights.....
Old Feb 26, 2014 | 11:24 AM
dannymicks's Avatar
What if you keep blowing fuses when you put in a new 15 amp fuse? Dash lights and running lights dont work but my brake lights work.
Old Feb 26, 2014 | 11:59 AM
scope103's Avatar
New 15amp fuse? Where? http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
Assuming you're replacing the "TAIL" fuse and not the "STOP" fuse, you have a short somewhere in the TAIL circuit (which includes the clearance lights, tail lights, and the combination meter (instrument panel) lights, but not the Stop lights (brake lights)).
I'd start by pulling the taillights and just looking at them; it's a harsh environment and sometimes the wires just rot away. Of course, like any electrical problem, this will all go much easier with your trusty multimeter.
Old May 3, 2014 | 11:00 AM
futbolboy's Avatar
I am having the same problem and I do have the trailer light converter box on there. how do I get around that or remove it?
Old May 4, 2014 | 08:25 PM
RAD4Runner's Avatar
Find where they tap into your stock harness and remove the pinch connector. Then inspect everywhere they punctured your wiring to make sure NOT A SINGLE WIRE STRAND was cut, and that there is no corrosion. IF any, fix it and thoroughly insulate and waterproof that junction.
Then incinerate that infectious trailer conversion device. It is a plague - LOL!
Old May 12, 2014 | 09:12 AM
futbolboy's Avatar
thnx. got it out, problem gone... couldn't get it to stay lit though
Old Oct 22, 2014 | 05:20 PM
Flinstone's Avatar
Does anyone know where all the stock ground connections are? If so can you list them?
Old Oct 22, 2014 | 06:39 PM
howardkm23's Avatar
I had same issue on an 89.
Pulled both rear taillight housings. Gasket was jacked allowing moisture in. Cleaned everything the best I could, scraped connections with a knife coated everything with elect. grease sealed up with new gasket and magically everything started working again.
