Dash lights stay on.....
Old Apr 29, 2014 | 07:02 AM
81 Toyo's Avatar
My dash lights for brake, battery and trans temp all are staying on for some reason?...seems to be running fine and charging fine according to gauge, temps are right where they should be on gauges....tried disconnecting battery briefly to see if it was a fluke but they remain on.....any ideas?
Old Apr 29, 2014 | 08:24 AM
81 Toyo's Avatar
This is on my 94 SR-5 w/3.0...
Old Apr 29, 2014 | 08:26 AM
JasonYota's Avatar
The brake light could be on if the fluid is low in the master cylinder.
But when all three being on at the same time I'd think it was an electrical problem.
Old Apr 29, 2014 | 08:59 AM
HighLux's Avatar
bad ground or alt on way out
Old Apr 30, 2014 | 08:28 AM
81 Toyo's Avatar
Checked and cleaned ground on alt and battery, checked all fuses, if the alt was on the way out would it still show up as charging?....the trucks running fine so I can't help but think its something simple, hate to take it to a "real" mechanic but may have no choice if can't solve it here...thanks
Old Apr 30, 2014 | 09:01 AM
RAD4Runner's Avatar
Final Answer
Final Answer
If "L" output of alternator is low (enclosed in yellow below), it will cause all three of the above lights to turn on.
See this for explanation.
Old Apr 30, 2014 | 09:10 AM
teaMJPx's Avatar
Yep, alternator... I had this issue on an old 89 4Runner. It was the alternator that was causing the issue.
Old Apr 30, 2014 | 11:52 AM
81 Toyo's Avatar
Thanks for that Final Answer!!.....looks like I'll be pulling the old alt out.
Old Apr 30, 2014 | 03:54 PM
RAD4Runner's Avatar
NP, but don't pull out alt until you have done suggested voltage checks.
For example, Alt may still be good BUT IF red wire from Engine fuse is broken or you have poor connection to engine fuse, you woulld have same problem.
Best of luck
Old May 1, 2014 | 07:39 AM
81 Toyo's Avatar
That was it!.....put in new alt this AM, problem solved....thanks for all your help with the diagnosis guys....
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
ViperTT
Aug 14, 2015 05:27 AM
nonstop
Jul 24, 2015 06:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
