Old Feb 10, 2016, 09:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
CV, Ball joint, TRE, replacement write up with PICTURES!!
Old Oct 4, 2010 | 08:02 PM
  #41
nlinn's Avatar
Appreciate this writeup man, pictures are some of the best on any thread on Yotatech.
Just got my drivers side done this weekend, should have sprayed those six nuts connecting to the differential down before hand though....huge pain to get them out.
Lesson learned
Old Oct 4, 2010 | 08:08 PM
  #42
toyospearo's Avatar
Lesson learned
Yup! I sprayed those days in advance. A good friend of mine who worked on Yotas for years told me it would be a GIANT headache if I didn't soak those days beforehand.
Thanks for the compliment!
Old Dec 15, 2010 | 06:40 AM
  #43
CitrusTheDragon's Avatar
Does anyone know the size of the big axle nut at the end of the half shaft. I would search but I am on my way to work and need to pick up the tool for tonight
Old Dec 15, 2010 | 07:21 AM
  #44
toyospearo's Avatar
I think it is 54mm?
Old Dec 15, 2010 | 09:20 AM
  #45
AxleIke's Avatar
54 mm.
Old Dec 15, 2010 | 05:04 PM
  #46
thanks guys
Old Dec 28, 2010 | 01:12 PM
  #47
Utah4Runner86's Avatar
Bump for a nice writeup, wish I'd found this before I did mine last summer.
I'll second the shims to hold the upper a-arm when lining up the BJ spacer, and a solid whack with a hammer on the outside of the hub right next to the cone washer will pop those things free and send them flying across the driveway to chip the paint on your wife's car.
Old Dec 28, 2010 | 05:47 PM
  #48
noble's Avatar
Would anyone recommend replacing the steering center link while doing this?
Old Dec 28, 2010 | 05:51 PM
  #49
noble's Avatar
great writeup... Helped me immensely
Old Mar 26, 2011 | 12:22 PM
  #50
87hillbillyoter's Avatar
im going to bump this thread because this will help me a ton when i do my cvs this week. awesome write up man!!!
Old Mar 29, 2011 | 01:41 PM
  #51
briholt's Avatar
By the way folks, if you are bumping the thread so that it shows up on your subscribed list, you can skip that and just go the the 'thread tools' and select the option to add it to your subscribed list. "thread tools" is a link towards the top of the page, just under the page number, a bit to the left.
Cheers
Old Nov 23, 2011 | 12:40 PM
  #52
xxxtreme22r's Avatar
hey man need yur help. Where did you get that new knuckle seal at? Remember the part number off hand? Was that a single piece that went in there or two pieces? Can't tell from the photo, but does that steel dust shield extend beyond the knuckle or sit flush with the hole?
Old Feb 28, 2012 | 07:37 AM
  #53
lastname_firstname's Avatar
Cheers
"But then My post count doesnt go up"
This write up is godly-im doin my ball joints this afternoon after work and this writeup basically does the work for me awesome
Old Feb 28, 2012 | 01:06 PM
  #54
toyospearo's Avatar
Old Apr 8, 2012 | 07:25 PM
  #55
Zombie Mobile's Avatar
Thanks and a few pointers
Just wanted to thank you for the great write up. Perfect pics, I even followed the breakfast directions to a T! Just a few things that helped me out.
Removing the shock was key. I used a floor jack to get it in the air, then a bottle jack on the bottom of the brake disk area, not the disk per say, but under it. I struggled with getting the half shaft in until I got it up in the air enough to slide it in.
I locked the other hub and took it in and out of 4wheel to help the axle from spinning. I used pivoting sockets with a breaker bar and air to get it off of the differential.
Took about four hours to complete both sides with new shocks...my other shocks were so shot that it wouldn't even rebound! Caused a wobble at 65 to 70 mph. Now smooth as butter!
Thanks for the write up, directions and pictures, my ride hasn't felt better.
Pics to come.
Old Apr 8, 2012 | 08:21 PM
  #56
toyospearo's Avatar
Glad it helped!!
Old Jun 9, 2012 | 11:23 AM
  #57
TURBOrunnerNM's Avatar
hey toyo. i'm replacing both of my CVs in my 86 4runner and got all the way to the part where the CV is ready to slide out. nuts off, snap ring and washer off, etc. however, i can't get the damn CV to slide out! the diff side of it is caught on those damn bolts. i jacked the lower control arm up so that there was no more travel in it and there is a lot of play in the CV but there doesn't seem to be any way that it will clear the diff lip and allow me to push it through. any suggestions?
Old Jun 9, 2012 | 11:41 AM
  #58
I did it last night, you have to unscrew the lower ball joint and pop the knuckle off of it and that gives you enough space to slide it past. I had to pop three of The bolts on the side shaft side of the diff off to get it past them...used a 5 lb sledge and a few good wacks with my 1/5 in. Extensions. Good luck
Old Jun 9, 2012 | 12:30 PM
  #59
scope103's Avatar
Once you jack up the lower control arm it should come out (you might try jacking on the rotor instead of the control arm. It's the end of the half-shaft you're trying to move, and there is a little slack through the ball joints). Some folks have found they have to lift the opposite corner a little, in order to compress the suspension enough on the corner you're working on (I've never needed to do that.)
And no, you don't have to unscrew the ball joints or remove the knuckles. And you certainly don't have to take a sledge hammer to the differential flange. Seriously; why would one think that Toyota designed a vehicle that required that sort of destruction for a common maintenance task?
Old Jun 9, 2012 | 02:16 PM
  #60
Yea...funny thing about that method, I tried exactly that and it didn't work. Nothing worked. I reasearched on here for hours trying to find the right way and finally settled on unscrewing the lower ball joint to cock the bottom of the hub out which was THE ONLY method that WORKED FOR ME. Think of it as a last resort.
Note: I have a 4 inch lift and removed my bump stops and sway bars too.
