Crankshaft turning
Old 01-31-2018, 03:43 PM
FunkMaster88's Avatar
Crankshaft turning
How far can a crankshaft be turned, i know there .010 .020 and .030...can it be turned .040?
Old 02-01-2018, 02:54 PM
gsp4life's Avatar
I think .030" over is the max for rod and mains. Mine are .030" over and a reputable local shop thought that was reground to the max. My machine shop couldn't find bigger bearings when I asked about it (for future rebuild purposes). 22re performance only sells bearings up to .020" over and they were skeptical about using .030" over bearings.
My cylinders are bored .040" also, so when this one dies, I'll just build up a new short block. Sounds like a new crank might be in your future if you need a regrind and are already at .030".
Old 02-02-2018, 12:10 AM
Thommo Thompson's Avatar
For toyota, of this era; bearings are available up to a maximum of 0.75mm undersize (0.295 inches)
so tgats it I'm affraid.
u can get sleeves but I've got no experience in them and no idea how they work.
Old 02-02-2018, 12:12 AM
Actually nah sleeves are for the oil seal of tge the shaft only. So forget that.
have u got bad knock?
Old 02-03-2018, 02:19 AM
wallytoo's Avatar
wouldn't that be 0.030 under, rather than over, as the new rod or crank journals will be smaller diameter than original?
Old 02-03-2018, 07:21 AM
Co_94_PU's Avatar
oversized bearings (they are thicker), for an undersized crank shaft.
Old 02-03-2018, 09:18 AM
wallytoo's Avatar
right, i guess it depends on which part. the journals get ground -under, while the inserts are thicker than standard. i'd always seen rod/mains listed as undersize for the thicker inserts, even though the inserts are thicker.
fwiw, the pistons in my flathead dodge are 0.060-over, and there are both 0.080-over and 0.100-over pistons available for it, although the walls between the cylinder pairs are pretty thin at 0.100-over. i'd probably sleeve it rather than use 0.100-over pistons, though.
Old 02-03-2018, 04:13 PM
Not quite guys. Undersize means, the back face of the bearing is std and the journal face is undersize. (for shafts that have been ground back)
oversize means the back face of the bearing is larger but the journal face is std. (for block that have been ground out)
if u have found a supplier who sais (advertises their products) otherwise, they have cocked up and need to realign themselves with industry std nomenclature.
and believe it or not, u can't get both and under and over. If u grind the crank and machine the block ur stuffed. Haha.
Old 02-03-2018, 04:17 PM
Here is a diagram.
https://lh3.googleusercontent.com/pr...w=w227-h647-nc
dntsdad
3.4 Swaps
59
10-15-2021 04:17 AM
The_One
04-25-2017 09:50 PM
kazuya2416
03-31-2017 04:24 PM
Rock Slide
63
02-07-2012 08:05 AM
Rock Slide
37
04-03-2007 08:26 AM
Quick Reply: Crankshaft turning
