Crank bolt 2, me 0 :D
#61
Stuck bolts are such a pain! I took a spindle nut (36mm i think) off of an Accord axle once that required a 3/4" drive socket. I put a cheater pipe on it (about 36" or longer), stood on the end, and jumped until the handle bent and then it finally came off! Probably took 750 ft-lb of so...
Good luck with it! Tenacity will win the day!
#62
Ha! Yeah I have to take a steady hand to that flange for sure. I am going to buy a new PS pulley anyways because mine is screwed from the PO. Its got a big gouge in it.
Yes we got slammed by the storm! It was weird cause it missed NorCal, and came in and nailed us? Free water! woohoo!
Seriously, can't wait to see the pics or whatever where you say "IT'S OFF!" ..... Best wishes, Baja,
Mark
#64
Baja
Here is the thread I used a couple of years ago when I was having trouble. This will give you a better visual about what needs to be done to get that thing off. It saved me so much time and patience.
Good luck
http://www.pirate4x4.com/forum/showt...ght=crank+bolt
Good luck
#65
Blamalam
Mar 12, 2022 07:34 AM
TJWilly
Jul 31, 2015 02:05 PM
v_man
Jul 23, 2015 04:01 PM
