Coolant hose part number
Old Feb 21, 2018 | 09:12 AM
Paul H.'s Avatar
Hey everyone, after some neglect I am finally coming around and doing some much needed maintenance on my 92 4Runner. So fay I have done a drain and fill on my tranny, shifts much better now, and replaced the main upper and lower coolant hoses and well as flushed the system out. While looking at all the other hoses it seems like the only hose that appeared in bad enough shape to replace is the one that runs below the oil filter and comes up right next to the main lower hose. I believe I found the part number but I am not sure. The number I got is 16281-65010. Is that correct? This is the 3.0. Thanks.
Old Feb 21, 2018 | 09:25 AM
scope103's Avatar
16281-65010 is the coolant hose from the throttle body forward to a vertical fitting next to the FPR. https://parts.lakelandtoyota.com/sho...rimLevel=18186
I don't have a coolant line near the oil filter, but I believe there exists an optional oil cooler; it sits under the filter, and is plumbed to the outlet of the water pump. i don't know which models have that, so I can't quickly look for it.
Where did you get your number?
Old Feb 21, 2018 | 10:32 AM
Paul H.'s Avatar
Just researching on the web and I did find the site you listed. I was hoping this was it but I guess not. Thanks.
Old Feb 22, 2018 | 06:23 AM
mkivbren's Avatar
I can post these shortly if needed - i'm replacing all coolant lines & radiator. Just picked up a 91. My parts guy knows most of these off the top of his head so I'm lucky. I have the oil cooler and both lines coming off that are beyond their lifespan.
Old Feb 22, 2018 | 07:59 AM
Co_94_PU's Avatar
Long hose, lower
15777A HOSE, OIL COOLER
Short hose, upper
15777HOSE, OIL COOLER
Old Feb 22, 2018 | 08:14 AM
Paul H.'s Avatar
Originally Posted by Co_94_PU
Long hose, lower
Short hose, upper
That is not the one I was looking for but it did lead me to the 15778-65010 hose via this ebay link which looks very much like what I need.
. http://www.ebay.com/itm/GENUINE-TOYO...9Zf-js&vxp=mtr
Old Feb 22, 2018 | 08:15 AM
Paul H.'s Avatar
That would be awesome and I am sure it would help others too. Thanks.
Old Feb 22, 2018 | 08:38 AM
Paul H.'s Avatar
Long hose, lower
Short hose, upper
Forgive my ignorance but does oil or coolant run thru that hose?
Old Feb 22, 2018 | 08:40 AM
Co_94_PU's Avatar
yeah that is it, 15778 is an updated part number. Difference is the vibration shroud and maybe a tweak to the bends.
Old Feb 22, 2018 | 08:42 AM
Co_94_PU's Avatar
its coolant. That hunk of metal between the engine block and oil filter is a heat exchange, oil cooler.
Old Feb 22, 2018 | 08:53 AM
Paul H.'s Avatar
Awesome. Thank you.
Old Feb 24, 2018 | 04:24 AM
mkivbren's Avatar
Looks like the ones. Suggest replacing the spring clamps too
Cannon88
May 20, 2018 12:10 PM
Paul H.
Feb 21, 2018 09:10 AM
angrybob
Mar 24, 2012 11:57 PM
Gerdo
Feb 3, 2008 10:44 AM
Ptotherez
Mar 9, 2007 10:06 AM
