Cold Start Injector
Old Feb 16, 2007 | 08:37 AM
4x4countrygirl's Avatar
Cold Start Injector
My boyfriend's 88 runner has been starting rough ever since it got cold out. The gas mileage is horrible (about 100 miles per tank in a V6 16 gallon tank) and it sounds pretty bad when you rev the engine. Once it's warmed up, it runs fine again. So, from reading other posts, we are pretty sure it's the cold start injector. Does that sound right?
Anyways... we are going to be working on the truck this weekend and decided that if we could, we would like to replace the cold start injector too. However, we need some help and direction on how to do it. Anyone have some ideas as to how we should go about replacing it? We're not really sure where to start... we have the Haynes manual to go off of and that's about it. Thanks!
Old Feb 16, 2007 | 08:54 AM
rdlsz24's Avatar
6 miles per gallon? lol. Do you already have the link for the FSM?
http://personal.utulsa.edu/~nathan-b...88coldstar.pdf
I like to use a combination of it and a Haynes or Chiltons.
Rob
Old Feb 16, 2007 | 08:59 AM
linuxrunner's Avatar
sounds like cold start injector try...
https://www.yotatech.com/forums/show...start+injector
or FSM page here:
http://personal.utulsa.edu/~nathan-b...ne/97colds.pdf
Good Luck, I don't have the 3.0, but maybe try unpluging the injector and see if it gets better.
(looks like Rob beat me, the link he gave you i think is for the 22re tho)
Old Feb 16, 2007 | 09:15 AM
Robrt32's Avatar
Rob
That link there ive seen it in a few threads and my puter does not open it.. I just have a blank screen.. I'm not very puter literate , what am i lacking to veiw it?
Old Feb 16, 2007 | 09:23 AM
deathstalker's Avatar
adobe acrobat reader. if you do have acrobat installed, try doing a save as, save it to your desktop, then open it from there.
Old Feb 16, 2007 | 09:42 AM
rdlsz24's Avatar
Yeah you need Acrobat Reader. It's free: http://www.adobe.com/products/acrobat/readstep2.html
Rob
Old Feb 16, 2007 | 09:46 AM
Turd Ferguson's Avatar
Few months ago my CSI malfunctioned and dumped several gallons of gas into the motor (it was backing up thru the exhaust manifold). The wire in the harness that controls it corroded and it wouldn't shut off. My mechanic traced the problem down, and bypassed it. I've been running without it for about 3+ months.
On cold starts it takes a little to crank it over, but a squirt of starter fluid and it fires right up. It idles high (around 1800 rpm) for a few minutes then drops down to around 1K RPM and eventually settles to normal after the oil gets going.
The ÅÅÅÅty gas mileage is a problem, though. Seafoam the motor and see if it improves any.
Old Feb 16, 2007 | 09:47 AM
Robrt32's Avatar
I saved it too desktop and saw it fine.......Thanks alot...I learned alot from it
Old Feb 16, 2007 | 09:49 AM
Robrt32's Avatar
Rob
Thats the way i have to crank mine now with starting fluid... It runs fine and gets around 27 miles to the gallon.. but it would be nice not having to pop the hood every cold morning
Old Feb 16, 2007 | 09:57 AM
We have seafoamed the engine and not much change if any. It actually is a completely rebuilt engine that we replaced just this last summer. So, new engine but all the rest are old parts... is there anything else that be causing such a HORRIBLE gas mileage problem that we should be looking into?
Old Feb 16, 2007 | 10:42 AM
I also forgot to ask about how long it would take to replace the cold start injector? How much work is involved?
Old Feb 16, 2007 | 11:56 AM
Marc's Avatar
If it's the 3.0 it takes 5 to 10 minutes to replace.
The hardest part is getting the clip off the connector.
Old Feb 16, 2007 | 01:00 PM
Chapman88SR5's Avatar
Can anyone describe or show me a picture of where the CSI is?
Old Feb 16, 2007 | 04:25 PM
^VooDoo^'s Avatar
Another way to check if the coldstartinjector or the enginetemp sensor, Take the plug off the CSI, If its harder to start then the CSI is fine, If no change then It may be the Enginetemp sensor, Thats on the backside of the engine and its the one on the left.
This is also a symtom of a O2 sensor not working or warming up, Check its harness and plug.
Old Feb 16, 2007 | 04:34 PM
SoCal4Running's Avatar
Is it not possible that the CSI is just plain leaking even when the plug is disconected????Hence the bad MPG.
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
steve miller
Oct 10, 2015 01:40 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
